Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement
  1. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the top edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  2. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Heat the bottom edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to power off your device before you begin your repair.
    • Heat an iOpener and apply it to the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  4. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Separate the adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Separate the adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  6. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Heat the right edge: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
  7. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive becomes hard to cut, it has most likely cooled down. Apply a heated iOpener to the edge to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Heat the top edge: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  9. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  10. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Heat the left edge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the left edge of the back cover for two minutes.
  11. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a fifth opening pick underneath the bottom left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~3-4 mm) to avoid damaging the power and volume button flex cable.
  12. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the back cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the back cover: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  13. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Slice the adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Slice the adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
  14. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Disconnect the charging coil: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Disconnect the charging coil: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
  15. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Disconnect the NFC antenna: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Disconnect the NFC antenna: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
  16. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Unfasten the NFC antenna & charging coil assembly screws: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Unfasten the NFC antenna & charging coil assembly screws: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
  17. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Unfasten the loudspeaker: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Unfasten the loudspeaker: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the loudspeaker assembly.
  18. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Disconnect the loudspeaker: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Disconnect the loudspeaker: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of a spudger between the frame and the upper-left notch in the loudspeaker.
    • Pry up with the spudger to release the loudspeaker from its plastic clips.
  19. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the NFC antenna & charging coil assembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the NFC antenna & charging coil assembly: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
  20. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the battery's press connector.
  21. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Disconnect the interconnect cables: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Disconnect the interconnect cables: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Disconnect the interconnect cables: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the primary and secondary interconnect cables' press connectors on the motherboard.
  22. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the primary and secondary interconnect cables' press connectors on the daughterboard.
  23. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the interconnect cables: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the interconnect cables: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the interconnect cables: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to remove the interconnect cables.
    • Set the cables aside. You'll reuse them during reassembly.
  24. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Unfasten the daughterboard: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Unfasten the daughterboard: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 3.4 mm-long screws securing the charging board.
  25. Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S21+ USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of a spudger under the upper left edge of the daughterboard and pry up to release it from its recess.
    • Use tweezers, or your fingers, to pull the daughterboard up and away from the bottom of the device and remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
173,836 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,719crwdne2935297:0
Can I use the USB-C charging port and daughter board from an SM-G996U to replace it with one from SM-G996B?
samuel - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 91
crwdns2942667:0crwdne2942667:0 3,951
