The Galaxy S10 has a hybrid SIM card tray. Ejecting this tray allows you to replace the nano SIM card, add a microSD memory card, or add a second nano SIM card (certain models only).
Insert a SIM card eject tool, SIM eject bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
Press firmly to eject the tray.
Remove the SIM card tray.
After you've completed the repair, follow this guide to test your repair.
Bravi, guida semplice e perfetta, molto chiara. Complimenti!
Mais dans quel compartiment faut-il mettre la carte sim ? Le petit ou le grand ? Je ne sais pas si “Nano” c’est le plus petit format. Merci.
Bernard LEROY - crwdns2934203:0crwdne2934203:0
Bonjour Bernard,
La carte SIM doit aller dans le petit compartiment.
Arthur Shi -
Be very careful to ensure that the SIM card does not fall out of the carrier while you are sliding it into the phone.
If it does fall out of the carrier while being inserted, you will find it nearly impossible to retrieve without damaging the phone circuitry.
You've been warned.
Patsy Hetzel - crwdns2934203:0crwdne2934203:0
