Samsung Galaxy S10+ SIM/MicroSD Card Replacement
  1. Samsung Galaxy S10+ SIM/MicroSD Card Replacement, SIM/MicroSD Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S10+ SIM/MicroSD Card Replacement, SIM/MicroSD Card: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S10+ SIM/MicroSD Card Replacement, SIM/MicroSD Card: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    So, I have owned multiple phones in my life and some of them had two doors, one for the Sim, one for the SD card. As it was darkish where I was installing the SD & SIM card, this is what I assumed my S10 plus 1tb had, and I poked a paper clip into the microphone hole and when it didn't open I pushed harder not realizing that it was the microphone. Some research that I've done says that the hole is straight and comes to an end and the microphone is 90° to that, so it cannot be poked by the pin, is this true(I hope it is!) ? I don't want to have to take apart my phone if I don't have to, to replace the microphone or God forbid the motherboard to replace one small component. Come on Samsung, is this planned obsolescence?
    Lin Car - crwdns2934203:0crwdne2934203:0
    Hi Lin,
    Good question! I took apart our S10 and that is indeed true! Inserting the SIM eject tool into the top microphone hole shouldn’t damage your microphone, or compromise water resistance.
    Here is a photo reference. The microphone hole is just an L-shaped tunnel drilled into the frame. At the end of the “L”, it is sealed by a thin waterproof gasket (red circle). The microphone is actually built into the motherboard (orange circle), which is pressed against this gasket. Sound is able to transfer across the thin gasket, but this design also allows it to be waterproof.
    I will edit the steps to reflect this information. Thanks for the heads up!
    Arthur Shi -
After you've completed the repair, follow this guide to test your repair.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
284.615 crwdns2915208:0crwdne2915208:0
crwdns2935297:0588crwdne2935297:0
Staff
crwdns2935297:019.864crwdne2935297:0
crwdns2947412:05crwdne2947412:0
I have the same question. I'm sure you've taken enough of these apart for repair. (Galaxy s10's and pluses) Can you guys see what's at the end of the hole? Any research that I've found says that the hole is straight and comes to an end and the microphone is 90° to that, so it cannot be poked by the pin, is this true? (I hope it is, and to give us peace of mind!) I don't want to have to take apart my phone. I'm sure there are lots people out here that have poked this %#*@ hole and are freaking that we have wrecked a $1600.00 phone! And then, if you could kindly please then post an answer plainly in the instructions for the SIM installation somewhere in the body of this installation article. I have seen no definitive answer to this mistake in any other article that I've read. Ifixit is the premiere repair company for phones, this should be solved here. Thanks in advance I hope. I've used your services multiple times in the past for various breakages of our family phones in Chicago, you've always been great.
Hi Lin,
Please look for the answer in step 1’s comments.
Arthur Shi -
I inserted the pin in the microphone hole first. Thank you for setting my mind at ease that I didn’t damage anything,
Craig Thielke - crwdns2934203:0crwdne2934203:0
Where can you order a OEM SM-G975U Prism Blue sim card tray from? I want a genuine Samsung replacement.
MarkC 609 - crwdns2934203:0crwdne2934203:0
well we have a dilemma here my s10+ ihas got a micro sim card stuck in the sd slot see if you can get it out by taking the phone apartand also ill need directions to you
Kevin Gaiser - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 107
crwdns2942667:0crwdne2942667:0 16,117
