Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement
  1. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
    very easy to follow instructions clear and concise
    Deric JONES - crwdns2934203:0crwdne2934203:0
  6. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
  8. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, SIM Card: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, SIM Card: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, SIM Card: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  9. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
  10. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, microSD Card: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, microSD Card: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, microSD Card: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  11. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
    Forgot about the step to remove the back casing...pretty simple though, just several screws then pop it off.
    Courtney - crwdns2934203:0crwdne2934203:0
  12. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Plastic Midframe: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
    What would you use to remove the screws
    Curt the heneke - crwdns2934203:0crwdne2934203:0
    I used both P#000 and J#00 precision bits to good effect. I tend to prefer the Japanese Standard bits in place of Philips, as the JIS bits seem not to cam out and strip screws as easily.
    E West -
  13. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
    • The midframe lightly snaps in place, and can be removed with very little force.
    There's another piece of the frame that needs to be taken out, but it doens't come out as nicely... unless I did something wrong. It's the part that covers the speaker. I couldn't find a nice way of taking it out.
    David - crwdns2934203:0crwdne2934203:0
    I had to use a guitar-pick to pry that section off of the frame. Start at the front-facing camera edge and run the pick underneath the plastic cover. The catches should release.
    Takashi Alekseev - crwdns2934203:0crwdne2934203:0
    I used a pointed prying too to get it started, then the flat one. It took some fiddling but finally came off nicely.
    Nick B - crwdns2934203:0crwdne2934203:0
    READ ME!
    For a guide that takes you step by step on how to remove the SIM and microSD, I'm surprised they didn't mention the top part of this midframe (still attached, in the pictures). This top part of the midframe also needs to be removed before you can take out the motherboard.
    You need to disconnect a ribbon not listed in these directions first, then pry that midframe up with the help of a guitar pick. This ribbon is located by the back-camera, next to the digitizer ribbon. This ribbon is connected to the midframe so it is essential you disconnect this before lifting the frame up.
    The frame is really snapped in there so don't be afraid to use a little force - for reference, you will use more force to pull this frame off than you did to pull off the back-cover of the phone. Once this piece is off, your phone should look like the picture in step 14.
    Jess - crwdns2934203:0crwdne2934203:0
  14. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
    • Make sure you are prying on the connector and not the socket, or you may damage the motherboard.
    This is not a rear facing camera connector. This is the connector for the lHeadphone Jack/Speaker Assembly
    Chasity Miller - crwdns2934203:0crwdne2934203:0
  15. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool outboard of the speaker portion of the headphone jack/speaker assembly.
    • Gently pry the headphone jack/speaker assembly up from the front assembly.
  16. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the headphone jack/speaker assembly out of the Galaxy S III.
crwdns2935229:098crwdne2935229:0
Walter Galan
701,723 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,203crwdne2935297:0
crwdns2947412:011crwdne2947412:0
Thanks for the guide. It's the most detailed that I have seen so far. I'm looking for a headphone jack assembly replacement part that is compatible with a verizon s3 (i535), but they are difficult to find. Some of the sellers on ebay are advertising that their replacement for the i9300 is compatible with the i535, but I am not sure. Can you please tell me where you purchased your headphone jack assembly replacement?
Thanks!
Wendy
Wendy - crwdns2934203:0crwdne2934203:0
I completed the tutorial but still have sound through the left and only on the right when I spin the jack AND apply pressure towards the phone. The part was brand new and all connections look good at a glance. I must have missed something though. Any ideas?
Nick - crwdns2934203:0crwdne2934203:0
i had the same problem (no sound through the right ear)
i followed the repair guide, teared it apart and then, when i had the jack out of it i used a flashlight and a soldering iron
my guide:
use a very thin soldering iron, make it really hot, put very much solder on it
then stick it in the jack you have to be VERY FAST!!! otherwise the plastic will melt
now you have solder on the contacts and they touch the headphone plug again :)
worked fine for me, but only do this when you know how to solder!
it's a little risky but it's worth it
cheers
Markus
markuslindner1 - crwdns2934203:0crwdne2934203:0
Ich habe mir das Teil besorgt und wollte es einbauen, habe aber 2 Schreuben nicht aufgedreht bekommen. Jetzt ist der Kopf ausgenudelt. Was kann ich machen?
atzeborg - crwdns2934203:0crwdne2934203:0
Thanks for the guide. We just replaced speaker assembly in my son's S3 with a $9 part off ebay, and it's working perfectly. Everything went like the pictures except there was slight difference between original and replacement. The hole next to the speaker in the replacement was a full circle, as in the last photo above, but the original was just a half-circle. We had to trim and file the replacement to match. Once we did that, it all snapped back together like new.
Greg - crwdns2934203:0crwdne2934203:0
Great guide, took onlz 5 minutes. And part from ifixit worked fine.
John Burden - crwdns2934203:0crwdne2934203:0
The models Samsung Galaxy S3 i9300 and Samsung Galaxy S3 i9301 use the same headphones socket?
ivfab - crwdns2934203:0crwdne2934203:0
Same , I too have this
PROBLEM
Zaid Ahmed - crwdns2934203:0crwdne2934203:0
I used this guide to repair a Samsung GT-1819ON which is a very similar, possibly UK spec of the phone. With this I was able to remove an obstuction from the audio jack which prevented me selling it on. The problem I was having was removing the plastic midframe Step 12. Once I had done this I was able to access the obstruction, remove it and reassemble. Thanks.
Pix - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 91,360
