Samsung Galaxy Note20 Ultra Motherboard Replacement
Kyle Smith
Kyle Smith
crwdns2944111:0February 16, 2023crwdne2944111:0
2 - 3 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Use this guide to remove or replace the motherboard on your Samsung Galaxy Note20 Ultra.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
crwdns2944105:0crwdne2944105:0
  1. Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the top edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  2. Samsung Galaxy Note20 Ultra Motherboard Replacement, Heat the rear cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely power off your phone before you begin disassembly.
    • Heat an iOpener and apply it to the left side of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen and internal battery are susceptible to heat damage.
  3. Samsung Galaxy Note20 Ultra Motherboard Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
    Great guide! Much appreciated! I've opened the phone twice now due to not gluing enough the first time. I wish iFixit sold a battery for the N20 Ultra. I had to get generics and one was total garbage.
    Steven Roberts - crwdns2934203:0crwdne2934203:0
  4. Samsung Galaxy Note20 Ultra Motherboard Replacement, Begin to cut the adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Begin to cut the adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Begin to cut the adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  5. Samsung Galaxy Note20 Ultra Motherboard Replacement, Cut along the perimeter of the rear cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Cut along the perimeter of the rear cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Cut along the perimeter of the rear cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While cutting through the adhesive, don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
    • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
    • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
    • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
    • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
    A que temperatura debe calentarse el teléfono para retirar la tapa trasera?
    Carlos Lozano - crwdns2934203:0crwdne2934203:0
  6. Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the rear cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the rear cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the rear cover straight up to remove it.
  7. Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the wireless charging coil: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the wireless charging coil: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  8. Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the white press connector: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the white press connector: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
    can i buy the motherboard shield
    Chu Lawrence - crwdns2934203:0crwdne2934203:0
  9. Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the motherboard shield screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
    • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
  10. Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the wireless charging coil: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the wireless charging coil: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the wireless charging coil: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to lift up the motherboard shield.
    • Be careful when handling the motherboard shield because its edges are thin and sharp.
    • Use your fingers to grip the motherboard shield.
  11. Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the wireless charging coil up and away from the device to remove it.
    • The wireless charging coil is secured to the device with light adhesive.
  12. Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
  13. Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the laser AF sensor: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the laser AF sensor: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to pry up the laser AF sensor press connector.
  14. Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the earpiece speaker screws: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 4.0 mm screws securing the earpiece speaker.
  15. Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the earpiece speaker: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the earpiece speaker: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of a spudger into the hole marked by a small triangle on the right side of the earpiece speaker.
    • Use the spudger to pry up and loosen the earpiece speaker from the frame.
    • The earpiece speaker clips to the frame along the top edge.
  16. Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the earpiece speaker.
  17. Samsung Galaxy Note20 Ultra Motherboard Replacement, Front-Facing Camera Cable Disconnection: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Front-Facing Camera Cable Disconnection: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the front-facing camera cable from the motherboard.
  18. Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the display cable: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the display cable: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
  19. Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the interconnect cables: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the interconnect cables: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
  20. Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
  21. Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the remaining cables: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the remaining cables: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the remaining cables: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the touch layer cable from the motherboard.
    • Use the pointed end of a spudger to disconnect the green press connector from the motherboard.
  22. Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the S-Pen press connector from the motherboard.
  23. Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the motherboard screws: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 4.0 mm screws securing the motherboard to the frame.
  24. Samsung Galaxy Note20 Ultra Motherboard Replacement, Loosen the motherboard: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Loosen the motherboard: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the bottom edge of the motherboard.
    • Pry up to loosen the motherboard from the frame.
    where did the interconnect and battery cables go??? kinda important it would seem.
    Isaac L - crwdns2934203:0crwdne2934203:0
  25. Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the motherboard: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the motherboard: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard out of the phone.
    • Be careful not to damage the disconnected press connectors and their cables while removing the motherboard.
  26. Samsung Galaxy Note20 Ultra Motherboard Replacement, Check cables during reassembly: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When you reinstall the motherboard, make sure that no cables get trapped under the board as you lower it into place. Check these seven locations carefully:
    • Secondary interconnect cable
    • Battery cable
    • Main interconnect cable
    • Display cable
    • S-Pen cable
    • Touch layer cable and green press connector
    • Front-facing camera cable
  27. Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the camera press connectors: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Disconnect the camera press connectors: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the ultra wide camera from the motherboard.
  28. Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the telephoto camera from the motherboard.
  29. Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the wide-angle camera from the motherboard.
  30. Samsung Galaxy Note20 Ultra Motherboard Replacement, Move the ribbon cable: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Bend the ultra wide camera ribbon cable away from the motherboard so that the rear camera assembly can be removed.
    • Don't bend the ribbon cable more than 90 degrees to avoid damaging it.
  31. Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the rear camera assembly: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the rear camera assembly: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note20 Ultra Motherboard Replacement, Remove the rear camera assembly: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The rear camera assembly is secured to the motherboard with light adhesive to the right of the telephoto camera.
    • Remove the rear camera assembly from the motherboard.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to secure the new rear camera assembly to the motherboard.
  32. Samsung Galaxy Note20 Ultra Motherboard Replacement, Only the motherboard remains: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only the motherboard remains.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
45,390 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
Hi. Guys. just found out my note 20 ultra motherboards gone. great guidelines. thanks. where can I get the motherboard from. and how much does it cost?
Zaid Sulaiman - crwdns2934203:0crwdne2934203:0
I bought one from ebay for 68.00
John Johnson - crwdns2934203:0crwdne2934203:0
I went to a water park and the phone was soaked in water. I left it in the rice container for 3 days out in the sun and it finally booted up. The phone was in airplane mode, no wifi, no network. I did a reboot and still nothing. When i ejected SIM tray it said no SIM found but when i put it back in, no network or wifi. I tried to reset wifi and network several times but didn't help. I cannot do a factory reset because it says i needed wifi. At this point im guessing these 2 features are on 1 component and it got damaged somehow. What part do i order so i can swap out and bring my phone back to life? Thank you
Note20 Lover - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 191
crwdns2942667:0crwdne2942667:0 12,554
