Use this guide to remove or replace the daughterboard on your Samsung Galaxy Note20 Ultra.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Great guide! Much appreciated! I've opened the phone twice now due to not gluing enough the first time. I wish iFixit sold a battery for the N20 Ultra. I had to get generics and one was total garbage.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
A que temperatura debe calentarse el teléfono para retirar la tapa trasera?
Lift the rear cover straight up to remove it.
Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to lift up the motherboard shield.
Use your fingers to grip the motherboard shield.
Peel the wireless charging coil up and away from the device to remove it.
Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
Use a Phillips screwdriver to remove the five 4.0 mm screws securing the loudspeaker to the frame.
Insert the pointed end of a spudger into the hole marked by a triangle on the left side of the loudspeaker.
Use the spudger to pry up and loosen the left side of the loudspeaker.
Insert the pointed end of a spudger into the hole marked by a triangle on the right side of the loudspeaker.
Use the spudger to pry up and detach the loudspeaker from the frame.
Use a pair of tweezers to lift and remove the loudspeaker.
Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
Use a Phillips screwdriver to remove the 3.0 mm screw securing the daughterboard to the frame.
Insert the pointed end of a spudger under the right side of the daughterboard near the screw boss.
Use the spudger to pry up and detach the daughterboard from the frame.
Use a pair of tweezers to lift and remove the daughterboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
crwdns2935229:05crwdne2935229:0
Do this Daughter Board has charging connection with the battery through flex cable
