Use this guide to replace the battery on your Samsung Galaxy Note20 Ultra.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Great guide! Much appreciated! I've opened the phone twice now due to not gluing enough the first time. I wish iFixit sold a battery for the N20 Ultra. I had to get generics and one was total garbage.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
A que temperatura debe calentarse el teléfono para retirar la tapa trasera?
Lift the rear cover straight up to remove it.
Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to lift up the motherboard shield.
Use your fingers to grip the motherboard shield.
Peel the wireless charging coil up and away from the device to remove it.
Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
Use a Phillips screwdriver to remove the five 4.0 mm screws securing the loudspeaker to the frame.
Insert the pointed end of a spudger into the hole marked by a triangle on the left side of the loudspeaker.
Use the spudger to pry up and loosen the left side of the loudspeaker.
Insert the pointed end of a spudger into the hole marked by a triangle on the right side of the loudspeaker.
Use the spudger to pry up and detach the loudspeaker from the frame.
Use a pair of tweezers to lift and remove the loudspeaker.
Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
Flip the secondary interconnect cable away from the battery.
Bend the display cable back so you can access the battery.
Bend the main interconnect cable back.
Apply 1-2 drops of high-concentration (90% or higher) isopropyl alcohol to the open spaces in each corner of the battery.
Wait two minutes for the isopropyl alcohol to weaken the adhesive underneath the battery.
Got stuck here, the adhesive is just not coming out. Is it possible my 91% alcohol has evaporated to a lower percentage, making this less effective?
Apply a suction cup to the center of the battery.
Pull up on the suction cup with a steady force to create a gap between the bottom edge of the battery and the frame.
Insert the point of an opening pick into the gap created between the bottom edge of the battery and the frame.
Push the pick under the battery to cut through the adhesive and detach the battery from the frame.
Pull up on the suction cup to remove the battery.
If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
crwdns2935229:020crwdne2935229:0
crwdns2947412:07crwdne2947412:0
where did you buy the new battery from?
What is the precut adhesive card used for?
Thank you so much!!! My battery was starting to bulge badly. While the life was still satisfactory, the shape of my phone was beginning to become very distorted, the side buttons no longer worked properly in my DBrand case, and when I pressed my finger on the fingerprint sensor, my screen would depress and click. Not only did you offer the battery and tools needed, but a perfect guide to installing it. Simply amazing.
I just wish you would lose the ridiculous communist imagery on your branding. Repairing products is not communist, it just makes sense. Let's make right to repair an American virtue again, and not model the movement off some Maoist revolution.
Just want to note, I bought the precut adhesive, and battery adhesive from this guide, only to start looking around more and find that Ifixit also sells the note 20 ultra 5G precut adhesive so you don't need to deal with putting the precut adhesive strips around the edge.
Fun note, it also comes with the battery adhesive, so now I have an extra battery adhesive, as well as precut tape strips that I probably will never use, or if I do use, will probably never be able to find them... lol
I made this same mistake of ordering an extra battery adhesive when I ordered last month. I guess I just read the title, as the description mentions the battery adhesive.
David M -
I think including an instructional video would be much more helpful
Pefect!! Thx a lot.
Note:
In addition to the double-sided adhesive film for the rear glass cover, it is also a good idea to buy the double-sided adhesive film for the camera base - this adhesive had also completely dissolved in my case - identical to the one on the cover.
Attention: I was sent an original double-sided adhesive film set (-> N-GH82-23364A). However, the double-sided adhesive film on the camera base was much too large, i.e. either fake or not for the Note 20 Ultra 5G.
In order to be able to reassemble the device, an emergency solution is therefore:
Allony black cell phone glue, cell phone display glue, multi-purpose glue, smartphone adhesive, liquid housing parts, display, touchscreen, glass, etc. - 50ml (black)
Unfortunately, the iFixit set is not available in Europe. Galaxy Note20 Ultra/20 Ultra 5G Rear Cover Adhesive
The new original battery is already supplied with the double-sided adhesive film.⏎
