Samsung Galaxy Note20 Screen Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace the screen on your Samsung Galaxy Note20.
The fingerprint sensor is embedded in this phone’s screen. If your fingerprint sensor isn’t working, you will likely need to replace the entire screen.
Some images may show the loudspeaker and earpiece speaker removed from the device. You don’t have to remove the speakers for this repair.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. If you’re trying to reuse the screen, be sure to apply plenty of heat and be extremely careful during the prying stage.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Lift the rear cover straight up to remove it.
Do NOT pull the shield away until you go to step 7 and 8 and 9.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to lift up and flip back the motherboard shield.
While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the battery press connector.
dove compro la nuova porta USB-C?! Where do I buy the port?!
While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the wireless charging coil press connector.
Grip the motherboard shield with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to disconnect the touch layer cable connector from the motherboard.
Heat an iOpener and apply it to the top of the screen for two minutes.
Apply a suction cup to the heated top edge of the screen, as close to the edge as possible.
Pull up on the suction cup with a steady force to create a gap between the screen and the frame.
Insert the tip of an opening pick into the gap at a steep angle. Push down the opening pick so that it is level with the screen.
Leave the opening pick in the gap to prevent the adhesive from re-sealing.
Insert a second opening pick into the gap.
Slide it to the top left corner of the screen to cut the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from re-sealing.
Insert a third opening pick into the initial gap.
Slide it to the top right corner to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from re-sealing.
Push the center opening pick farther into the phone to cut through the adhesive surrounding the earpiece speaker and front-facing camera.
Remove the center opening pick.
Apply a heated iOpener to the right edge of the screen for two minutes.
Insert another opening pick into the gap in the top right corner of the screen.
Slide the opening pick down to the bottom right corner to cut through the adhesive.
Leave the opening pick in the bottom right corner to prevent the adhesive from re-sealing.
Insert the tip of an opening pick under the center of the right edge of the screen at a steep angle.
Leave the opening pick in the center of the right edge of the screen to prevent the adhesive from re-sealing.
Apply a heated iOpener to the left edge of the screen for two minutes.
Insert another opening pick into the gap in the top left corner of the screen.
Slide the opening pick down to the bottom left corner to cut through the adhesive.
Leave the opening pick in the bottom left corner to prevent the adhesive from re-sealing.
Insert the tip of an opening pick under the center of the left edge of the screen at a steep angle.
Leave the opening pick in the center of the left edge of the screen to prevent the adhesive from re-sealing.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the right edge of the screen to weaken the inner adhesive near the fingerprint sensor.
Tilt the phone so that the isopropyl alcohol flows toward the inner adhesive.
Wait two minutes for the alcohol to weaken the adhesive.
Hold the top half of the frame up so that the touch layer cable can be threaded through its cutout.
Lift the screen up from its top half while threading the touch layer cable through its cutout in the frame.
*The replacement ifixit screen does not come with a new display cable so you will have to carefully remove it from your old screen and reattach it to your new one.
Thread the display cable and touch layer cable through their cutouts in the frame as you remove the screen.
Remove the screen.
FOR CUSTOM NOTE 20 ADHESIVE (that came with the ifixit screen replacement kit): There is a foam pad that ended up my rear adhesive slip that looks like it goes below the front camera under the screen. Don't be like me and find this out after the new screen adhesive & screen has been reattached.
Also: the OEM rear cover adhesive has a non-sticky strip in between the adhesive and in my case stayed attached after I removed the cover. There is same under the camera plate. (It looked like it was intende to remain there but the new adhesive looks like it also has it and if you leave it, it might be just enough out of tolerance to prevent the cover from appearing flush upon reassembly)
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Answers community for help.
crwdns2935229:011crwdne2935229:0
Over priced for the digitizer, crappy to call people stupid
I used this guide today for a screen replacement. This guide is a great way to keep track of screws.
