Use this guide to replace the motherboard on your Samsung Galaxy Note20.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the top edge of the phone.
Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
Remove the SIM card tray.
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Lift the rear cover straight up to remove it.
Do NOT pull the shield away until you go to step 7 and 8 and 9.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$17.96
Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to lift up and flip back the motherboard shield.
While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the battery press connector.
dove compro la nuova porta USB-C?! Where do I buy the port?!
While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the wireless charging coil press connector.
Grip the motherboard shield with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use a Phillips screwdriver to unscrew the five 4.0 mm screws securing the loudspeaker to the frame.
Insert the pointed end of a spudger underneath the loudspeaker near its top left screw hole.
Use the spudger to pry up and detach the loudspeaker from the frame.
Use a pair of tweezers to lift and remove the loudspeaker.
Use a Phillips screwdriver to remove the five 4.0 mm screws securing the earpiece speaker to the frame.
Insert the flat end of a spudger underneath the bottom edge of the earpiece speaker.
Pry up the earpiece speaker to loosen it from the frame.
Lift and remove the earpiece speaker.
Use the pointed end of a spudger to pry up the front-facing camera press connector.
Use a pair of tweezers to remove the front-facing camera.
Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
Use the pointed end of a spudger to disconnect the S-Pen press connector from the motherboard.
Use the pointed end of a spudger to disconnect the green press connector from the motherboard.
Use the pointed end of a spudger to disconnect the touch layer press connector from the motherboard.
Use a Phillips screwdriver to remove the 4.0 mm screw securing the motherboard to the frame.
What is on the right side attached by the two black screws? My note 20 lacks it.
Insert the pointed end of a spudger under the bottom left corner of the motherboard.
Pry straight up to loosen the motherboard from the frame.
Lift the motherboard out of the phone.
Turn the motherboard over so that the rear camera module's press connectors are facing upward.
Use the pointed end of a spudger to pry up the upper camera's press connector from the motherboard.
Use a pair of tweezers to lift and remove the upper camera from the motherboard.
Use the pointed end of a spudger to pry up the lower cameras' press connector from the motherboard.
Lift and remove the lower cameras from the motherboard.
Only the motherboard remains.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Answers community for help.
crwdns2935229:08crwdne2935229:0
Hi There ... is the phones data storage located in the motherboard? things such as photos?
