Use this guide to remove or replace the motherboard on your Samsung Galaxy Note10.
Prepare an iOpener and apply it to the left edge of the back panel for one minute.
Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Insert a second opening pick and slide it across the left side towards the top left corner to slice the adhesive.
Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it to the top edge of the phone for one minute.
Insert a third opening pick into the gap on the top edge of the phone.
Slide the opening pick to the top right corner, slicing the adhesive.
Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it to the right edge of the phone for one minute.
Insert a fourth and final opening pick into the gap on the right side of the phone, sliding it down towards the bottom right corner of the phone to slice the adhesive.
Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
Lift up and remove the back panel.
Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
Tilt the metal shielding up so you can grip it with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use a Phillips screwdriver to remove the four 4 mm screws securing the top plastic cover.
Use a pair of tweezers to pivot the top plastic cover up and off of the phone.
Use the pointed end of a spudger to pry the front-facing camera connector straight up from the motherboard.
Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
Use a pair of tweezers to remove the loudspeaker.
Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
Disconnect the secondary interconnect cable from the motherboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
Disconnect the secondary interconnect cable from the daughterboard.
Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the top edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to disconnect the side button connector from the motherboard.
Disconnect the touch layer connector from the motherboard.
Use the pointed end of a spudger to disconnect the S-Pen charging coil connector from the motherboard.
Use the pointed end of a spudger to pry up the motherboard enough to grip it with your fingers.
Remove the motherboard.
missing steps to remove piece above the wireless coil. You guys went from wireless coil to the bottom of the phone to remove the daughter board and skipped entirely how to remove the top piece above the coil.
