Samsung Galaxy Note10+ Rear Cover Replacement
  1. Samsung Galaxy Note10+ Rear Cover Replacement, Heat the rear cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy Note10+ Rear Cover Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10+ Rear Cover Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10+ Rear Cover Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Samsung Galaxy Note10+ Rear Cover Replacement, Begin to slice the adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10+ Rear Cover Replacement, Begin to slice the adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10+ Rear Cover Replacement, Begin to slice the adhesive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note10+ Rear Cover Replacement, Slice around the perimeter of the phone: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10+ Rear Cover Replacement, Slice around the perimeter of the phone: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note10+ Rear Cover Replacement, Slice around the perimeter of the phone: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • The rear cover will begin to separate from the phone as you finish all sides of the phone.
  5. Samsung Galaxy Note10+ Rear Cover Replacement, Lift off the rear cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note10+ Rear Cover Replacement, Lift off the rear cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the rear cover straight up to remove it.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
    • If you're using Tesa tape to reattach components, follow this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
crwdns2935229:012crwdne2935229:0
Carsten Frauenheim
155,795 crwdns2915208:0crwdne2915208:0
crwdns2935297:0439crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:023,729crwdne2935297:0
Depending on how rough you back glass is. Mine was a shattered mess. It might take almost 2 hours. But mine was a worst case scenario. But be patient and slow and you are sure to be rewarded with a beautiful new back glass! Keep at it my friends! No need to ditch that phone yet!
Melody Chaser - crwdns2934203:0crwdne2934203:0
Great tutorial, I replace real cover with battery. Now my Note list like new.
Łukasz Wiewióra - crwdns2934203:0crwdne2934203:0
I can open it easily without any problems
Stasiu Dettlaff - crwdns2934203:0crwdne2934203:0
Tuve dificultad para abrirlo, definitivamente como ya estaba rota la tapa trasera, no tuve tanto cuidado, sin embargo, esta guía fue de ayuda para no empezar por otra parte y porsupuesto usar calor de una pistola. Lo ideal sería usar una precalentadora, pero hablamos de hacerlo en casa y no cualquiera tiene herramientas de técnico. Le falta a la guía mencionar cómo quitar el pegamento que queda, lo mejore es limpiarlo y usé un poco de alcohol isoproólico para remover el pegamento pero la verdad aún así tuve dificultades. Limpié lo más posible. Al retirar la tapa me llevé una sorpresa donde había un tornillo suelto y más flojos, así que ajusté todo y volvió a funcionar la carga inalámbrica.
gigastec - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 111
crwdns2942667:0crwdne2942667:0 10,138
