Use this guide to remove or replace the screen on your Samsung Galaxy Note10+ 5G.
Due to the Note10+ 5G’s design, you will have to remove the back panel in order to disconnect the screen cable.
Before you begin this procedure, be sure to have a set of replacement adhesives for both the back panel and the screen.
This guide uses steps written for the non-5G Note10+. Some images in this guide may show minor discontinuities. They shouldn’t affect the overall guide procedure.
Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
Lift the rear cover straight up to remove it.
Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
Tilt the metal shielding up so you can grip it with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to disconnect the S-Pen touch layer cable connector from the motherboard.
Prepare an iOpener and apply it to the left edge of the display for one minute.
Apply a suction cup to the heated edge of the display, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the display and the frame.
Slide the opening pick along the left side towards the bottom left corner to slice the adhesive.
Insert a second opening pick and slide it along the left side towards the top left corner to slice the adhesive.
Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it to the bottom edge of the phone for one minute.
Insert a third opening pick into the gap on the bottom edge of the phone.
Slide the opening pick to the bottom right corner, slicing the adhesive.
Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it to the top edge of the phone for one minute.
Insert a fourth opening pick into the gap on the top edge of the phone.
Slide the opening pick to the top right corner, slicing the adhesive.
Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it to the right edge of the phone for one minute.
Slide the opening pick from the top right corner down towards the bottom right corner of the phone to slice the adhesive.
Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
Lift the screen up from the top edge of the phone.
Thread the display and S-Pen touch layer cables through their cutouts on the phone frame.
Remove the display.
Remove any leftover adhesive before installing a new display.
Be sure to test your repairs before installing new adhesives.
crwdns2935229:017crwdne2935229:0
Thank you so much. Well put together, even as a tech head I would not have attempted this without a guide and this is the place to come for any guide required!!
Sly Si 84 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Dear Sir
My note 10 plus screen broken. I need a new screen.
Tariq Hasan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
