crwdns2959928:0crwdne2959928:0 ↓Check the device's troubleshooting page before replacing the SIM card. Also make sure you are installing the correct SIM card.
You may want to install a new SIM card if you change carriers, want a new phone number, cannot make calls, or cannot receive service anywhere.
Spudger4.9
Make sure the screen is face-down and the camera is opposite you.
Insert the flat end of a spudger into the phone's top right rectangular slot.
Use the spudger as a lever to pry open the back of the phone.
With the spudger still inserted, carefully slide the spudger down the side of the phone.
Gently peel off the back cover with your hand.
Place the spudger in the battery's bottom right slot.
Gently pry to remove the battery.
Pull out the (white and blue) SIM card directly above the empty battery slot.
