Samsung Galaxy Note SD Card Replacement
crwdns2869540:0crwdne2869540:0: 1.3K
5
19
1,316
crwdns2959984:0crwdne2959984:0: 3
crwdns2959974:03crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 3 - 5 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
The SD card holds your phone's external memory. Replace or remove the SD card if you want to change how your phone deals with memory storage. Check the device's troubleshooting page if you think your SD card is malfunctioning.
    1. Samsung Galaxy Note SD Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note SD Card Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note SD Card Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Make sure the screen is face-down and the camera is opposite you.
      • Insert the flat end of a spudger into the phone's top right rectangular slot.
      • Use the spudger as a lever to pry open the back of the phone.
    2. Samsung Galaxy Note SD Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With the spudger still inserted, carefully slide the spudger down the side of the phone.
      • Gently peel off the back cover with your hand.
    3. Samsung Galaxy Note SD Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the spudger in the battery's bottom right slot.
      • Gently pry to remove the battery.
    1. Samsung Galaxy Note SD Card Replacement, SD Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull out the micro SD card located in the upper right slot (above the battery).
David Ritter
crwdns2935283:004/14/13crwdne2935283:0
758 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-45, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 3-45, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S3G45
crwdns2935297:084crwdne2935297:0
crwdns2959996:0crwdne2959996:0 1,316
