Samsung Galaxy Note Micro USB Port Replacement
  1. Samsung Galaxy Note Micro USB Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Micro USB Port Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Micro USB Port Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
  2. Samsung Galaxy Note Micro USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
  3. Samsung Galaxy Note Micro USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
  4. Samsung Galaxy Note Micro USB Port Replacement, Midframe: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
  5. Samsung Galaxy Note Micro USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the stylus from the bottom of the phone.
  6. Samsung Galaxy Note Micro USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Micro USB Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Note Micro USB Port Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
    • If the cover does not come off easily, continue to pry along the phone's perimeter.
    • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Separate the midframe from the phone. The midframe should now pull off easily.
  7. Samsung Galaxy Note Micro USB Port Replacement, Micro USB Port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the phone so the screen is on the table and the USB port is facing you.
    • Disconnect the orange ribbon near the bottom of the device using a spudger.
  8. Samsung Galaxy Note Micro USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3mm screws on the bottom of the device with a Phillips #00 screwdriver.
  9. Samsung Galaxy Note Micro USB Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black rectangular bracket imprinted with a "7" where you just removed the screws. The piece should pop off easily.
    • Disconnect the antenna (white wire) with a spudger by prying the metal part gently off.
  10. Samsung Galaxy Note Micro USB Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note Micro USB Port Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide spudger under the USB port and gently drag it left and right to remove the port from the phone.
    • Adhesive keeps the USB port from moving, so it might not pull up right away.
crwdns2935229:020crwdne2935229:0
David Ritter
crwdns2935283:004/14/13crwdne2935283:0
758 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-45, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 3-45, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S3G45
crwdns2942667:0crwdne2942667:0 6,709
