Samsung Galaxy Note 3 Rear Facing Camera Replacement
Brittany Gail
crwdns2944107:0crwdnd2944107:0Brittany Gailcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Huk 7, 2018crwdne2944111:0
crwdns2931273:0crwdne2931273:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This guide shows how to replace the camera.
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
crwdns2944105:0crwdne2944105:0
  1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove the rear case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Why... is it not simple enough already lol
    Adam Ahmed - crwdns2934203:0crwdne2934203:0
  3. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Rear Facing Camera Replacement, S Pen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unscrew Back Chassis: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Back Chassis: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single screw beside headphone jack.
    You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
    Oriol Felisart - crwdns2934203:0crwdne2934203:0
  8. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Motherboard Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up on the motherboard with tweezers.
    Can i change at&t board to 9002 or 9005??,
    Ayyaz - crwdns2934203:0crwdne2934203:0
    My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
    soha Javed - crwdns2934203:0crwdne2934203:0
    My wifi hotspot is not working
    Kiran Thopate - crwdns2934203:0crwdne2934203:0
  10. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unclipping the Camera: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the camera connecting cable using the plastic opening tool from the motherboard
    • Remove loose camera from base
crwdns2935229:037crwdne2935229:0
Brittany Gail
crwdns2935283:009/23/14crwdne2935283:0
8,530 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 2-2, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S2G2
crwdns2935297:025crwdne2935297:0
Awesome, phone disassembly and fingernail painting at same time :) Thanks for your time to post this!
Chris G - crwdns2934203:0crwdne2934203:0
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
hameidfehri - crwdns2934203:0crwdne2934203:0
I shall be very thankfull for this act of kindness
Malik wajdan ali - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 13,599
