Samsung Galaxy Core Screen Replacement
  1. Samsung Galaxy Core Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Core Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Core Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the phone over and use your fingernail or an opening tool to remove the back cover.
  2. Samsung Galaxy Core Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Core Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
    • If your phone has a SIM card or MicroSD card, remove them.
  3. Samsung Galaxy Core Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 9 Phillips #00 screws from the mid-frame.
  4. Samsung Galaxy Core Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Core Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to pry off the mid frame.
  5. Samsung Galaxy Core Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Core Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the following ribbon cables from the motherboard:
    • The digitizer and LCD assembly.
    • Headphone Jack and Earpiece.
    • Daughter board flex cable.
    • Antenna connector.
  6. Samsung Galaxy Core Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Core Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Core Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to remove the motherboard.
  7. Samsung Galaxy Core Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Core Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Core Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single Phillips screw that secures the daughterboard.
    • Remove the daughterboard.
    • The flex cable is glued, so exercise extreme caution, as excessive force can damage the cable.
  8. Samsung Galaxy Core Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Core Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Core Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening pick to remove the audio jack.
  9. Samsung Galaxy Core Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Core Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the digitizer's ribbon cable.
  10. Samsung Galaxy Core Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the earpiece mesh outwards to release it.
  11. Samsung Galaxy Core Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a heat gun or an iOpener to heat the digitizer and soften the glue securing it.
    • Use an opening pick to break up the glue around the edges of the digitizer.
    • You may apply more heat if needed.
    • Remove the digitizer and any broken glass.
crwdns2935229:090crwdne2935229:0
ivan coene
crwdns2935283:003/12/14crwdne2935283:0
3.006 crwdns2915208:0crwdne2915208:0
crwdns2947412:011crwdne2947412:0
yes, but where can I buy the screen replacement?
Roxannie - crwdns2934203:0crwdne2934203:0
Comment root galaxy core prime g361f android 5.1.1
soulaemen - crwdns2934203:0crwdne2934203:0
Follow the instructions in reverse order? Do you need glue for the new screen? What kind of glue? How is it applied?
Thomas McGuigan - crwdns2934203:0crwdne2934203:0
Nor do they show how the new digitizer plugs in...
chris smith -
Magkano po ang magagastos lcd and touch po ung papalitan
ramil cariaga - crwdns2934203:0crwdne2934203:0
Is the Potentially Dangerous part when you work with the glass? Just curious if there was some other hidden danger?
Sara - crwdns2934203:0crwdne2934203:0
Jup, it's only because you work with broken glass ;)
ivan coene -
I have 2 devicies.
#1 broken LCD+digi
#2 dead with fine LCD+digi
Can I swap whole screen (LCD+digi) together with frame?
Piotr Jaremko - crwdns2934203:0crwdne2934203:0
Never tried, but i guess you could just stop at step 9...
Let me know if it worked
ivan coene -
I own and use a core prime as my phone, it has a shattered screen, verizon wont replace it because it was a warrentty replacement for my kyocera brigadir that i dropped in the ocean, it works again btw just a bit slower, but i cant afford a new phone, and i cant deal with the glass splinters any more, i dont want to spend more then i have to, are some of these required things actually needed? Like the seperation tools, can i do the same thing with say an automotive trim tool(already have one)? It looks similar at the prying tip. Maybe a high end hair dryer instead of a heat gun? (My gf has one i can use). My true goal is to spend only the cost of the replacement parts, as i do not currently have a steady income. Thanks in advance for any advise.
S1l3ntb0b696 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 117,136
