Samsung Galaxy Camera Lens or Motherboard Replacement
  1. Samsung Galaxy Camera Lens or Motherboard Replacement, Lens or Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gather your camera and tools. Also make sure that the battery is removed before proceeding.
    • Follow battery replacement guide through step three to remove the battery.
  2. Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all seven 4 millimeter long screws using the PH000 screwdriver bit.
  3. Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use plastic opening tool to remove the cover on the non-lens side of the camera.
  4. Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
    • Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
  5. Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use plastic opening tool to pull connector away from motherboard.
    • Remove screen completely and set aside.
  6. Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, disconnect the three connectors from the motherboard.
  7. Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3.5 mm long screws (red circle markers) using the PH000 screwdriver bit.
    • Remove the four 2 mm long screws (orange circle markers) using the PH000 screwdriver bit.
  8. Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 3 mm long screws connecting the lens unit to the main housing using the PH000 screwdriver bit.
    • Carefully remove the lens and motherboard from main housing.
    I allready had two cases in which the screw to the left wasn't installed.
    jakob_tries_fixing_things - crwdns2934203:0crwdne2934203:0
  9. Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Camera Lens or Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove stickers off of connectors.
    • Open latch door on connectors.
    • Separate lens from motherboard.
    • Now you may replace either motherboard or lens with new part.
    Only lenz assembly need to change we're I order the part asap
    RENZ PEDROCHE - crwdns2934203:0crwdne2934203:0
crwdns2935229:09crwdne2935229:0
Keith Lipking
crwdns2935283:009/26/15crwdne2935283:0
386 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-3, Wilson Fall 2015 crwdns2935289:0IUPUI, Team 2-3, Wilson Fall 2015crwdne2935289:0
IUPUI-WILSON-F15S2G3
Would love a video of this, as well.
David CrossmN - crwdns2934203:0crwdne2934203:0
Hey after you replace the motherboard do you just turn the camera on and it works?
Ive done it and some chinese characters show up in a dialog box...
Sam - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,663
