Begin removing the 3/16" screws for the device.
Turn the device and remove the additional 3/16" screws.
Turn the device and remove the additional 3/16" screw.
Using the plastic opening tools, pry open the camera from the bottom.
Gently pull the connector away from the motherboard.
Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
Pull these connectors away from motherboard.
Lift the motherboard and lens out of the case.
crwdns2935229:010crwdne2935229:0
Hey mate, what do you do after the motherboard replacement? Just turn the camera on? Do you need to do a master reset?
