Samsung Galaxy Buds Plus Case Battery Replacement
  1. Samsung Galaxy Buds Plus Case Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you proceed, discharge your battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Open the case and remove both of the earbuds.
  2. Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening tool between the interior plastic cover and the exterior case.
    • This may take multiple tries at different contact angles.
    • Once inserted, pry up to begin separating the interior cover from the exterior case.
    • Move the opening tool around the edge until all of the clips holding the interior cover in place are released.
    • Remove and place the interior cover to the side.
  3. Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the four screws holding the case's lid and hinge.
    • All of the screws in this guide share the same head and are the same length.
  4. Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the case over to the back.
    • Use a nylon spudger to pry and pop out the hinge from the body of the case.
  5. Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two screws on either side of the USB-C port.
    • Remove the metal shielding from the USB-C port.
    • Remove the final Phillips #000 screw securing the motherboard and battery to the case.
  6. Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly hold the case in one hand and pull out the motherboard and battery from the case using two fingers.
  7. Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the LED indicator and gently detach it from the plastic housing of the motherboard using the spudger.
  8. Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the board over and peel off the wireless charging coil.
    • Be careful not to break the two thin wires connecting the charging coil to the motherboard.
  9. Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the motherboard from the battery and plastic housing.
  10. Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the positive and negative terminal pads that are connected to the battery.
    • The corner that is diagonal to the correct pads should not have any pads.
    • Use the spudger to detach the pads from the plastic housing.
  11. Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a heat gun or hair dryer on medium to low heat to soften the battery adhesive for 20-30 seconds.
    • Insert the spudger between the battery and the plastic housing and gently pry up until the battery is free.
    • Overheating or puncturing the battery may cause it to ignite.
  12. Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Case Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the plastic housing.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Darius Nguyen
crwdns2935283:010/10/24crwdne2935283:0
259 crwdns2915208:0crwdne2915208:0
UC Davis, Team 1-5, Morris Fall 2024 crwdns2935289:0UC Davis, Team 1-5, Morris Fall 2024crwdne2935289:0
UCD-MORRIS-F24S1G5
This is an excelent guide. Followed it to the T and I would say there's nothing else to add. Thank you for it!
DMP - crwdns2934203:0crwdne2934203:0
How to fine samsung galaxy airduds lpus case battery
PREM LOVE - crwdns2934203:0crwdne2934203:0
Hey there! Here is an Amazon link where you can order the battery along with some tools too: https://a.co/d/8NPdu7n
Darius Nguyen -
Superb guide. Followed it step by step to disassemble and reassemble, was a breeze. Need to take note of the small pair of square and trapezoid magnets position before putting all parts back. Battery replacement price is around RM26.90 a piece in Malaysia (Shopee discounted price)
zul broq - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 71
crwdns2936753:030crwdne2936753:0 318
crwdns2942667:0crwdne2942667:0 2,632
