Samsung Galaxy Buds Plus Battery Replacement
  1. Samsung Galaxy Buds Plus Battery Replacement, Remove the eartip: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Remove the eartip: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If possible, discharge your Galaxy Buds+ before replacing the battery.
    • Use your fingers to remove the silicone eartip by pulling it upwards while slipping it off the earbud.
  2. Samsung Galaxy Buds Plus Battery Replacement, Remove the earbud's rubber wingtip: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Remove the earbud's rubber wingtip: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Remove the earbud's rubber wingtip: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers or a pair blunt nose tweezers to remove the earbud's rubber wingtip by pulling it upwards while slipping it off the earbud.
  3. Samsung Galaxy Buds Plus Battery Replacement, Create a gap: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Create a gap: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of pliers to hold the earbud horizontally along the seam between the upper and lower halves of the case.
    • To protect the earbud from scratches, tape the surface of the pliers or place a cloth between the pincers.
    • Apply steady, even pressure to either side of the earbud along the main housing seam to create a gap.
  4. Samsung Galaxy Buds Plus Battery Replacement, Insert an opening tool: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Insert an opening tool: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool into the gap between the two cases of the earbud.
    • Use the opening tool to pry the two cases apart.
    • You may need to work your way around the entire earbud with the opening tool.
    • Don't remove the upper case yet, it’s still connected to the board.
  5. Samsung Galaxy Buds Plus Battery Replacement, Access the connector: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Access the connector: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Access the connector: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure that the flex cable is not under tension during the following step.
    • To remove the upper part of the earbud from the board, place it on the table to access the connector.
    My ear buds speaker connecting wire patta is centre break plz help me
    Magic Concept - crwdns2934203:0crwdne2934203:0
  6. Samsung Galaxy Buds Plus Battery Replacement, Disconnect the upper earbud case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Disconnect the upper earbud case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Disconnect the upper earbud case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to disconnect the upper earbud case from the board by prying the connector out of its socket.
    • Remove the upper earbud case.
  7. Samsung Galaxy Buds Plus Battery Replacement, Lift the core assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Lift the core assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Lift the core assembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place an opening tool under one of the small lips of the core assembly.
    • Slightly lift the core assembly—including the motherboard—out of the buds case to access the battery.
    • Don't remove the core assembly completely—it's still attached to the case by a ribbon cable.
  8. Samsung Galaxy Buds Plus Battery Replacement, Remove the battery housing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Remove the battery housing: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery is housed in the plastic case.
    • Use a pair of blunt nose tweezers to remove the battery housing while holding the upper part with your fingers.
    • Be careful not to rip the thin motherboard flex cable.
  9. Samsung Galaxy Buds Plus Battery Replacement, Remove the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Plus Battery Replacement, Remove the battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to separate the housing from the battery.
    • Remove the battery.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
crwdns2935229:031crwdne2935229:0
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
58 902 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 959crwdne2935297:0
Just finished replacement of my batteries. My model didnt have the lower carrier but bad some thermal pads on the bottom PCB and the top plastic cover keeping the battery stable. I had to move the top PCB out of place, then take off the top plastic holder to get the battery out as it isnt physically connected to the top PCB. other then that it was much easier then i expected. THanks!!!!
Alexander Mike - crwdns2934203:0crwdne2934203:0
Thanks to your guide i was able to disassemble both of my earbuds for me to test the batteries since one of them wasn't charging, turns out one of the batteries is long gone, but i wouldn't be able to open them without your guide, THANKS!! Now is just a matter of getting the battery replacements and get them on the go again!
Linthux - crwdns2934203:0crwdne2934203:0
If your headphones are older like mine please keep in mind: the interior plastic that holds the battery was a salmon color for me and the headphone basically fell apart when trying to open it as the adhesive was very broken down. Everything still works fine, just was a little surprising when things just popped open with no force. Thanks iFixit. Lets keep these headphones going another 3 years.
jasiahruby - crwdns2934203:0crwdne2934203:0
Some picture of the old battery model so we can order it before the install would be very helpful. Thank you for your help 😉
Mihnea Ace - crwdns2934203:0crwdne2934203:0
LIR 1454 is the battery. Right at the top they have an advertisement for batteries and tools.
Ian Jaskela - crwdns2934203:0crwdne2934203:0
I have found that many of the lir1454 batteries do not fit the samsung buds plus. When you remove the battery there is a plastic grey ring around it and the new batteries are too big for the ring around it . Because of this when you try to reassemble it the battery is too big to get the pink piece above it in. Anyone know of a work around?
Victor Siegel - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 160
crwdns2936753:030crwdne2936753:0 608
crwdns2942667:0crwdne2942667:0 37,162
