Samsung Galaxy Buds Live Battery Replacement
  1. Samsung Galaxy Buds Live Battery Replacement, Insert an opening pick: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Live Battery Replacement, Insert an opening pick: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If possible, discharge your Galaxy Buds Live before replacing the battery.
    • Place the tip of an opening pick between the plastic cases on the curved inside of the earbud.
    • Insert the pick at a steep angle.
  2. Samsung Galaxy Buds Live Battery Replacement, Loosen the case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Live Battery Replacement, Loosen the case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Keep the opening pick at a steep angle and slide it along the top to loosen the case.
    • Take your time and do your best not to deform the plastic.
  3. Samsung Galaxy Buds Live Battery Replacement, Remove the case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Live Battery Replacement, Remove the case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the case.
  4. Samsung Galaxy Buds Live Battery Replacement, Disconnect the main connector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Live Battery Replacement, Disconnect the main connector: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to lift up and disconnect the main connector.
  5. Samsung Galaxy Buds Live Battery Replacement, Remove the motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Live Battery Replacement, Remove the motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Live Battery Replacement, Remove the motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to gently lift up the motherboard.
    • Remove the motherboard.
  6. Samsung Galaxy Buds Live Battery Replacement, Unscrew the plastic frame: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the 3.4 mm-long screw which is securing the plastic frame.
  7. Samsung Galaxy Buds Live Battery Replacement, Remove the plastic frame: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Live Battery Replacement, Remove the plastic frame: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Live Battery Replacement, Remove the plastic frame: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to remove the plastic frame by pulling it upwards.
  8. Samsung Galaxy Buds Live Battery Replacement, Clear the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Buds Live Battery Replacement, Clear the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to slightly lift up the speaker driver obscuring the battery.
    • The driver is held in place with light adhesive. Work carefully and don't tug on anything too hard.
  9. Samsung Galaxy Buds Live Battery Replacement, Pry up the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Live Battery Replacement, Pry up the battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Buds Live Battery Replacement, Pry up the battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery is held in place by a mild adhesive.
    • Insert the pointed end of a spudger underneath the battery.
    • Use constant, steady pressure to pry the battery up.
  10. Samsung Galaxy Buds Live Battery Replacement, Remove the battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
    • Do not reinstall a damaged battery, as doing so is a potential safety hazard.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
crwdns2935229:015crwdne2935229:0
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
58 839 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 880crwdne2935297:0
Thanks!!! This works great to clean the felt earwax filter underneath the metal grate as well!
Erin Rodriguez - crwdns2934203:0crwdne2934203:0
Graxias. Podrías indicarme la referencia de la bateria?
OMILU QUINTERO - crwdns2934203:0crwdne2934203:0
Thanks for the guidance.
It was easy to open the bud and to take it apart.
Just notice that there's no marking for + or - anywhere, to know on what side to put the battery. and the new one that I've got was wider then the plastic circle on the original battery.
Hananya Krishevsky - crwdns2934203:0crwdne2934203:0
I have a question. I can see that there is a battery contact point under the battery but that should be one of the terminals, right? Where is the contact for the other terminal? Is it part of the motherboard that sits on top of the battery?
NavK - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 21
crwdns2936753:07crwdne2936753:0 169
crwdns2936753:030crwdne2936753:0 627
crwdns2942667:0crwdne2942667:0 23,947
