Samsung Galaxy Amp 2 Screen Replacement
crwdns2942287:0crwdne2942287:0Repair your broken or damaged screen with this guide. A replacement may be needed if the screen is cracked or unresponsive. This guide recommends use of a heat gun, though a blow dryer can be used instead. Use care when applying heat to the screen and carefully detach delicate wiring to avoid damaging the phone.
crwdns2944105:0crwdne2944105:0
Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
Lift upwards and gently pry the rear panel off of the phone.
Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
Grip the battery and safely remove it from the phone.
crwdns2935267:0crwdne2935267:0Tweezers$3.99
Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
Disconnect the connector piece from the back panel.
Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
Use four plastic opening tools to gently pry off the screen.
I broke the screen on the same day I bought the phone. I have ordered a new one from ebay. I am going to try to install the screen with LCD digitizer.
I had an amp 2 phone i accidently smashed it with my ps3 controller when I was playing games I smashed it on purpose so is this the way to fix the phone
