Use this guide to replace a cracked or broken screen on your Galaxy A52.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
Before disassembling your device, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device. If you do not replace the adhesive seals when reassembling, your device will function normally, but will most likely lose its water protection.
Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
One should be very careful to not insert the pick more than 2-3mm into the phone, as you might damage a flex cable when sliding the pick to slice the adhesive. I accidentally cut the flex cable near the bottom right corner of the back cover!
A way to entirely avoid the risk of damaging that flex cable is to slide the pick up from the bottom to the top. That way, the pick cannot snag onto the flex cable. -
Slide the opening pick to the top right corner to slice the adhesive.
Leave the opening pick in its place to prevent the adhesive from resealing.
Insert a second opening pick underneath the top right edge of your phone.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom edge of your phone.
Slide the opening pick along the bottom edge of your phone to slice the adhesive.
Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
Insert a fourth opening pick underneath the bottom left corner of your phone.
Slide the opening pick along the left edge to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fifth opening pick underneath the top left corner.
Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
Remove the back cover.
Use a Phillips screwdriver to remove the ten 4.4 mm-long screws securing the motherboard cover.
Insert an opening pick underneath the left edge of the motherboard cover.
Use the opening pick to pry up the motherboard cover.
Remove the motherboard cover.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
The daughterboard cover needs to be removed as well before proceeding to step 12
Use the flat end of a spudger to disconnect the right connector of the interconnect cable from the daugtherboard.
Carefully bend the cable to the top of the phone to get access to the screen connector socket.
This is the bottom of the phone? It looks like the bottom not the top correct?
Bottom right is my guess, am I correct? The battery cable is on the top. These things are important to list guys! No ill compemt from me im just saying this is important.
Otherwise you'd have people unplugging the black main cable next to the battery plug. For those of us who don't work through batteries plus and what not.
Also there are 6 screws on the bottom plate to take that off. Then access the screen cable under that...
Insert an opening pick underneath the screen connector.
Pry up the screen connector.
Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
Apply a suction handle to the right edge of the screen.
Lift the screen with the suction handle to create a small gap between the screen and the frame.
Insert an opening pick into the gap between the midframe and the screen.
How? You have to hold the phone? I've been pulling and heating and this screen isn't coming off.
I had the same problem. The screen was extremely glued to the phone. I've used iOpener, with no luck, then tried hairdryer to the point, that the screen is almost not possible to touch. This thing wasn't budging. Finally got it off with the help of iSesamo. Most of the glue was in the middle of the screen, not around the frame.
For me, the glass and digitizer eventually separated from the screen itself, and the silvery reflective glass of the screen fragmented into lots of little pieces when trying to unglue it from the mainboard - so do not count on removing the display without permanently destroying it, if (like me) you still had that expectation from older phones.
Insert a second opening pick underneath the top right corner and slide it along the right edge to the bottom right corner of the screen to cut the adhesive.
Insert a third opening underneath the bottom right corner.
Slide the opening pick to the bottom left corner.
Insert a fourth opening pick underneath the bottom left corner and slide it along the left edge of the phone to the top left corner.
Insert a fifth opening pick underneath the top left corner and slide it along the top edge to cut the adhesive.
Reapply a heated iOpener to the screen to loosen the adhesive underneath.
In preparation for the following step, take note of the rectangular-shaped adhesive placed underneath the screen.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Insert a plastic card on the right edge into the gap between display and the phone assembly.
Press the plastic card in and slide it back and forth until you cut through the entire adhesive.
Once you are sure you cut through the adhesive, remove the four opening picks from the corners.
Carefully thread the screen cable through the frame.
Remove the screen.
All went perfect, almost too perfect. I swore I missed a part or something. I did notice, on a second set, that while I didn't replace solely the screen, but the combo set with the frame and screen together, The button that depresses the SIM eject lever, it's got two washer type rings on it, and I believe that weatherproofs it. It is not included on the frames, so make sure to remove that!!! Just depress the button with the SIM card ejector tool(or proper paper clip) and make sure to moisten the washer kinda points before reinserting. Same thing with the charge port/speaker/daughter board at bottom, the areas around the actual USB-C and headphone ports have rubber surrounds to weatherproof them, and it will take a little finagling, but if you moisten them just slightly, they'll eventually go and snap in. I use a small bit of 5 in 1 on my finger for all of these.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
crwdns2935229:032crwdne2935229:0
crwdns2947412:09crwdne2947412:0
I can't get the screen removed has anyone tips on how to do this
Same problem here. Removing the back cover, the battery, and the connectors is fiddly, but not too hard.
However, I have so far failed at the initial step for display removal (#15). Inserting the first tool in between case and battery just seems impossble, despite trying with both an iOpener and a fan for heating. Usually the suction cup gives way before I can exert enough force on the case to create even a tiny gap.
Props to Samsung for creating an extremely sturdy front cover, but not good for display repairability. Perhaps after three years the glue just turns as hard as Roman concrete?
My replacement display did not come with adhesive backing. Other than that everything worked out great. Just waiting on some adhesive strips to arrive before I get my Samsung back into service
This guide is good but don't use a card use something thinner like a thin piece of metal. The thing that says "follow this guide for reassembly" shows a screen with a new frame replacement. I pulled the LCD LIKE THIS GUIDE SAID....Now idk what to do so I guess ill wing it...this guide needs work, Adriana Zwink.
Do you know where I can buy the screen?
Ppp -
Is the 4g model use same screen with the 5g model?
cara memperbaiki touchscreen yang rusak bagaimana ya?
Recommededshop to buy amoled sxreens
איפה לקנות מסך אני לא מוצא... איפה כדאי לי להזמין?
