Samsung Galaxy A52 Screen Replacement
  1. Samsung Galaxy A52 Screen Replacement, Heat the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A52 Screen Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
    • If the back cover is damaged, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    One should be very careful to not insert the pick more than 2-3mm into the phone, as you might damage a flex cable when sliding the pick to slice the adhesive. I accidentally cut the flex cable near the bottom right corner of the back cover!
    A way to entirely avoid the risk of damaging that flex cable is to slide the pick up from the bottom to the top. That way, the pick cannot snag onto the flex cable.
    brechtm - crwdns2934203:0crwdne2934203:0
  3. Samsung Galaxy A52 Screen Replacement, Slice the adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Slice the adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  4. Samsung Galaxy A52 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick underneath the top right edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A52 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A52 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom edge of your phone.
    • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A52 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a fourth opening pick underneath the bottom left corner of your phone.
    • Slide the opening pick along the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A52 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A52 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick underneath the top left corner.
    • Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
  8. Samsung Galaxy A52 Screen Replacement, Remove the back cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Samsung Galaxy A52 Screen Replacement, Unscrew the motherboard cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the ten 4.4 mm-long screws securing the motherboard cover.
  10. Samsung Galaxy A52 Screen Replacement, Pry up the motherboard cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Pry up the motherboard cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Pry up the motherboard cover: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick underneath the left edge of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
    • Remove the motherboard cover.
  11. Samsung Galaxy A52 Screen Replacement, Disconnect the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Disconnect the battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    The daughterboard cover needs to be removed as well before proceeding to step 12
    Laurens Bolle - crwdns2934203:0crwdne2934203:0
  12. Samsung Galaxy A52 Screen Replacement, Disconnect the interconnect cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Disconnect the interconnect cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Disconnect the interconnect cable: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to disconnect the right connector of the interconnect cable from the daugtherboard.
    • Carefully bend the cable to the top of the phone to get access to the screen connector socket.
    This is the bottom of the phone? It looks like the bottom not the top correct?
    Zach Benson - crwdns2934203:0crwdne2934203:0
    Bottom right is my guess, am I correct? The battery cable is on the top. These things are important to list guys! No ill compemt from me im just saying this is important.
    Otherwise you'd have people unplugging the black main cable next to the battery plug. For those of us who don't work through batteries plus and what not.
    Also there are 6 screws on the bottom plate to take that off. Then access the screen cable under that...
  13. Samsung Galaxy A52 Screen Replacement, Pry up the screen connector: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Pry up the screen connector: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Pry up the screen connector: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The screen connector is adhered to the daughterboard with mild adhesive.
    • Insert an opening pick underneath the screen connector.
    • Pry up the screen connector.
  14. Samsung Galaxy A52 Screen Replacement, Heat the screen: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  15. Samsung Galaxy A52 Screen Replacement, Create a gap: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Create a gap: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Create a gap: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the right edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the midframe and the screen.
    How? You have to hold the phone? I've been pulling and heating and this screen isn't coming off.
    I had the same problem. The screen was extremely glued to the phone. I've used iOpener, with no luck, then tried hairdryer to the point, that the screen is almost not possible to touch. This thing wasn't budging. Finally got it off with the help of iSesamo. Most of the glue was in the middle of the screen, not around the frame.
    Martin Hasak -
    For me, the glass and digitizer eventually separated from the screen itself, and the silvery reflective glass of the screen fragmented into lots of little pieces when trying to unglue it from the mainboard - so do not count on removing the display without permanently destroying it, if (like me) you still had that expectation from older phones.
    Marcus Groeber - crwdns2934203:0crwdne2934203:0
  16. Samsung Galaxy A52 Screen Replacement, Slice the adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Slice the adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Slice the adhesive: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick underneath the top right corner and slide it along the right edge to the bottom right corner of the screen to cut the adhesive.
  17. Samsung Galaxy A52 Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun to for 1-2 minutes to reheat it.
    • Insert a third opening underneath the bottom right corner.
    • Slide the opening pick to the bottom left corner.
  18. Samsung Galaxy A52 Screen Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a fourth opening pick underneath the bottom left corner and slide it along the left edge of the phone to the top left corner.
  19. Samsung Galaxy A52 Screen Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A52 Screen Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick underneath the top left corner and slide it along the top edge to cut the adhesive.
    • When you slice near the front facing camera, insert only the tip of the opening pick (about 3 to 4 mm) to avoid damaging or smearing the camera.
  20. Samsung Galaxy A52 Screen Replacement, Reheat the screen: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Reheat the screen: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reapply a heated iOpener to the screen to loosen the adhesive underneath.
    • In preparation for the following step, take note of the rectangular-shaped adhesive placed underneath the screen.
  21. Samsung Galaxy A52 Screen Replacement, Insert the plastic card: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Insert the plastic card: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Insert the plastic card: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • Insert a plastic card on the right edge into the gap between display and the phone assembly.
    • Press the plastic card in and slide it back and forth until you cut through the entire adhesive.
    • Once you are sure you cut through the adhesive, remove the four opening picks from the corners.
    • Do not remove the screen completely yet. The display cable is still threaded through the frame.
  22. Samsung Galaxy A52 Screen Replacement, Remove the screen: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Remove the screen: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A52 Screen Replacement, Remove the screen: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully thread the screen cable through the frame.
    • Remove the screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
    All went perfect, almost too perfect. I swore I missed a part or something. I did notice, on a second set, that while I didn't replace solely the screen, but the combo set with the frame and screen together, The button that depresses the SIM eject lever, it's got two washer type rings on it, and I believe that weatherproofs it. It is not included on the frames, so make sure to remove that!!! Just depress the button with the SIM card ejector tool(or proper paper clip) and make sure to moisten the washer kinda points before reinserting. Same thing with the charge port/speaker/daughter board at bottom, the areas around the actual USB-C and headphone ports have rubber surrounds to weatherproof them, and it will take a little finagling, but if you moisten them just slightly, they'll eventually go and snap in. I use a small bit of 5 in 1 on my finger for all of these.
    Thomas - crwdns2934203:0crwdne2934203:0
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
crwdns2935229:030crwdne2935229:0
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
58,346 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,163crwdne2935297:0
crwdns2947412:09crwdne2947412:0
I can't get the screen removed has anyone tips on how to do this
Seppe De Schutter - crwdns2934203:0crwdne2934203:0
Same problem here. Removing the back cover, the battery, and the connectors is fiddly, but not too hard.
However, I have so far failed at the initial step for display removal (#15). Inserting the first tool in between case and battery just seems impossble, despite trying with both an iOpener and a fan for heating. Usually the suction cup gives way before I can exert enough force on the case to create even a tiny gap.
Props to Samsung for creating an extremely sturdy front cover, but not good for display repairability. Perhaps after three years the glue just turns as hard as Roman concrete?
Marcus Groeber -
My replacement display did not come with adhesive backing. Other than that everything worked out great. Just waiting on some adhesive strips to arrive before I get my Samsung back into service
Shannon Bish - crwdns2934203:0crwdne2934203:0
This guide is good but don't use a card use something thinner like a thin piece of metal. The thing that says "follow this guide for reassembly" shows a screen with a new frame replacement. I pulled the LCD LIKE THIS GUIDE SAID....Now idk what to do so I guess ill wing it...this guide needs work, Adriana Zwink.
Do you know where I can buy the screen?
Ppp -
Is the 4g model use same screen with the 5g model?
Jacki Naly Sam - crwdns2934203:0crwdne2934203:0
cara memperbaiki touchscreen yang rusak bagaimana ya?
Vera Trisalsabila - crwdns2934203:0crwdne2934203:0
Recommededshop to buy amoled sxreens
Marlon Austria - crwdns2934203:0crwdne2934203:0
איפה לקנות מסך אני לא מוצא... איפה כדאי לי להזמין?
מרדכי ניסנוב -
crwdns2936751:024crwdne2936751:0 37
crwdns2936753:07crwdne2936753:0 358
crwdns2936753:030crwdne2936753:0 1,485
crwdns2942667:0crwdne2942667:0 66,212
