Samsung Galaxy A50 Display Assembly with Frame Replacement
crwdns2936621:0crwdne2936621:0
  1. Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, LCD Display Assembly replacement: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Display Touch Screen Digitizer Assembly with Frame for Samsung Galaxy A50
  2. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery cover removal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat up the back cover to loosen the adhesive.
    • To separate the back cover use a Suction Cup and plastic tools.
  3. Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Middle frame removal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the SIM tray.
    • Remove the Philips Screws.
    • Again use plastic tools to separate the middle frame.
  4. Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Test the new spare part: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First disconnect the Battery.
    • Test the new spare part before the installation.
  5. Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Logic board removal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect and remove the Main Flex Cable.
    • Remove the black Philips screw, it's shorter then the middle frame screws.
    • Disconnect the coaxial antenna cable.
    • Now you can remove the logic board.
  6. Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Sub board removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First remove the Fingerprint sensor.
    • The screws for the Fingerprint are shorter.
    • It's better to use hot air before to disassemble the sub-board.
    • Reminder - only plastic tools :)
  7. Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A50 Display Assembly with Frame Replacement, Battery removal: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Again, hot air, plastic tools and very slowly remove the battery.
  8. Samsung Galaxy A50 Display Assembly with Frame Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All's Well That Ends Well
    non ho capito se per cambiare il display rotto devo smontare tutto il telefono compresa la scheda logica.
    Gino - crwdns2934203:0crwdne2934203:0
    The display came with the frame, so u just have to move the logic board to the new frame with screen already installed, usually screen that came with frame is OLED screen, because its tricky to install fragile OLED screen to the old frame.
    Zent -
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194,588 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01,699crwdne2935297:0
The frame I bought doesn't have the place for earspeaker surrounded by little "walls", so it's very loose and doesn't have contact with the board. Anyone experienced this?
knezi - crwdns2934203:0crwdne2934203:0
You can just use small amount of jelly glue to attach it to the frame it'll work fine as long its stay in a right place the logic board will help it keep it in place
Zent -
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 215
crwdns2942667:0crwdne2942667:0 17,140
