Use this guide to replace a broken display or cracked glass of your Samsung Galaxy A5.
Take an iOpener to heat up and soften the glue behind the back cover.
With a suction handle lift the back cover to insert an opening pick.
Slide the pick up to the middle to separate the back cover from the frame.
Insert a second opening pick and move around the right corner along the bottom and around the left corner.
Take another opening pick and continue towards the top corner.
Here you want to use one more pick for the last part at the top.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Insert a plastic card at the bottom and slide it underneath the back cover.
Heat up the back cover once again so you can slide the plastic card towards the top.
Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
Remove the SIM card tray.
Remove the 17 Phillips #00 screws on the midframe.
Push the exposed part of the battery away from the midframe to separate the components.
You may need the IMEI sticker on your old battery to identify your phone in the future, be sure to transfer it to the replacement battery.
With a flat end of a spudger disconnect the display connector.
Reheat the iOpener and use it to loosen the adhesive under the display.
Use a Jimmy to get between the frame and the front panel.
Pry up the display unit just a bit so you can put an opening pick behind the display.
Slide down the side to separate the glue. At the bottom you can insert the opening pick further to keep the adhesive from resealing.
Repeat the same procedure on the other side.
Here you can insert the opening pick as far as half of an inch to get the glue off behind the battery.
Slide down to where the display ends.
Now slide along the bottom to get the glue off.
Re-heat the display unit for the next few steps.
On the left hand side (where the motherboard sits) replace the opening pick with a plastic card to get to the glue behind the battery.
Continue separating the adhesive until you reach the display cable.
Separate the display from the display frame and cut the remaining glue at the top with an opening pick.
Carefully slide the display cable out of the slot in the display frame.
crwdns2935229:064crwdne2935229:0
crwdns2947412:08crwdne2947412:0
dear sir,
i follow the steps above but still my mobile with black screen and colored dots, what shall i do please help me
Dear sir
Mera Mobile gir jane ke karan screen tut gya h but work kar rha mai chahta hu ise repair karwana please contact me Mobile -7903248447
Miei parole ci sono sei molto bravo , grazie mille per tutorial , e ti mandò un mondo di salute e più grande fortuna dell' mondo Grazie…..
Evo da i ja ostavim komentar. kad vec svako na svoj jezik pise
Unfortunately, Croatian is not yet available on our site. A team of volunteers has already started localizing the iFixit user interface into Croatian, but there is still lots of work to do. We are using an open web translation software which is called "Crowdin". If you'd like to participate, you can just follow this link and create an account to start translating: https://crowdin.com/project/ifixit/hr# , but I would recommend that you read the iFixit translator guidelines first: Translator Guidelines Crowdin. If you’d like to get a notification as soon as we get started with Guide and Wiki translations in Croatian, you can just fill in this form:++ https://docs.google.com/forms/d/e/1FAIpQ.... I stay at your disposal for any further question or concern!
