Samsung Eternity Digitizer and Screen Replacement
    • Remove the back battery cover.
  1. Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Digitizer and Screen Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You have successfully removed the motherboard from the phone.
  10. Samsung Eternity Digitizer and Screen Replacement, Digitizer and Screen: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the phone over so you are looking at the front screen of the phone.
  11. Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone.
    • This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
  12. Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Eternity Digitizer and Screen Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
Heather Behrend
crwdns2935283:004/20/11crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-11, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 15-11, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S15G11
You did not mention how to glue the digitizer to LCD. That is a very important step.
cashyapan - crwdns2934203:0crwdne2934203:0
Do these steps also work for the Samsung Eternity 2?
Brian Coukis The 90's Kid! - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 6,939
