Use the guide below to help you replace the hinge for the Samsung Chromebook Pro.
Remove the eight 30 mm screws from the edges of the case with the JIS J000 screw bit.
Slide the plastic opening tool in a corner at a steep angle, and lift up to remove the outer case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Locate the two white wires and one black wire. With the flat precision tweezers, untangle the white wires from the CONAN >PC+ABS< # 1-1.
Completely disconnect the black wire.
Remove the three 30 mm screws using the JIS J000 screw bit from the black CONAN >PC+ABS< # 1-1 plate.
Once all the screws are removed from the CONAN >PC+ABS< # 1-1 plate, remove the wire attached to underside and lift the plate to remove.
Locate hinge plates LP1 and RP1 on the top left and right corners of the Chromebook.
Remove the two 30 mm screws from hinge plates LP1 and RP1 using the JIS J000 screw bit.
On the right top corner, locate the black and gold wire.
Lift the bar that is locking the wire in using the precision tweezers.
Disconnect the wire by grasping the black portion with the precision tweezers, and then pulling away from the Chromebook Pro.
Completely open the Chromebook and gently separate both halves.
Place the plastic opening tool at an angle in the gap between the hinge and Chromebook screen and lift up.
Completely remove the plastic screen lining using the plastic opening tool.
Remove the three 30 mm screws from hinge plate R1 and L1 using the JIS J000 screw bit.
Disconnect the black wire on the R1 plate connected to the screen using the precision tweezers.
Lift the hinge to remove from the Samsung Chromebook Pro.
How on earth do I find that specific replacement Hinge? I can't find it anywhere I have a Samsung Chromebook: XE513C24
crwdns2935229:05crwdne2935229:0
Great guide! One question: where can I buy the actual replacement hinge? Any tips?
I was able to find the hinges for mine on the Global Direct Parts web site. The item name is: OEM Samsung Chromebook Plus XE513C24, Pro XE510C24 Metal Hinge Set
How did you remove/unloop the cables in the hinges? do they just come right off?
Darby -
The cables are just pushed into the side of the hinge. One side had a stopper holding the cable in place that I had to pull out, but the other had nothing holding the cable (that was the broken hinge on my chromebook, so maybe it had a stopper that had fallen out at one point). Once the stopper was removed from the one hinge, I could pull the cables out, and push them into new hinges.
Just replaced these hinges on my computer … was only a bit confused with the stopper in the hinge but otherwise this guide was extremely helpful. Took about 30 min to do …
Do you know someplace I can order these hinges online?
