Samsung Chromebook Plus Battery Replacement
crwdns2942287:0crwdne2942287:0This guide will show you how to replace the battery for the Samsung Chromebook Plus.
crwdns2944105:0crwdne2944105:0
Remove the 8 PHILIPS#0 screws
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Stick a plastic card (or fingernail) into the gap between panel and the body. Then lift the panel up (long side with speakers closest).
Use your PHILIPS#0 and remove the 4 screws
Lift battery from bottom side first (marked with red line)
Detach battery cable grabbing the side and pulling the cable upward.
Insert the battery and push the plug into the socket downward.
Re-insert the screws in the holes circled red (on this image), which is where you removed them previously.
Insert the hinge-side middle screw (must be done first otherwise casing may bulge) and insert rest of panel. On the hinge side, press down on the sides (if there is bulging) until you hear it snap. Insert the two other hinge-side screws (marked with orange on image). After that, insert the other 5 screws (yellow).
Excellent tutorial! Replaced the batt on our Samsung Chromebook plus circa 2017-18. Ordered batt from seller on Ebay of new old stock. Thanks so much!
To reassemble your device, skip steps 1-5.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:06crwdne2947412:0
Great repair guide. Nice to see how easy it is to replace battery.
thanks for finding the battery part! Awesome job!
Fantastic guide, This made it so easy, especially the note on the cable which clicks in. Thank you so much for sharing.
