Samsung Captivate 3.5mm Headphone Jack Replacement
  1. Samsung Captivate 3.5mm Headphone Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate 3.5mm Headphone Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate 3.5mm Headphone Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the old battery with the new one.
  4. Samsung Captivate 3.5mm Headphone Jack Replacement, Rear Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate 3.5mm Headphone Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate 3.5mm Headphone Jack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Captivate 3.5mm Headphone Jack Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Captivate 3.5mm Headphone Jack Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate 3.5mm Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the rear case from the phone.
  8. Samsung Captivate 3.5mm Headphone Jack Replacement, Antenna Cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Captivate 3.5mm Headphone Jack Replacement, Antenna Cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
  9. Samsung Captivate 3.5mm Headphone Jack Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Captivate 3.5mm Headphone Jack Replacement, Motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Captivate 3.5mm Headphone Jack Replacement, Motherboard: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the spudger slide the tool under the three highlighted connectors to begin disconnection
    • Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
    • Be careful to not pry against the connector. Prying against could further damage to the device.
  10. Samsung Captivate 3.5mm Headphone Jack Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to carefully lift up the Samsung Capivate's Motherboard from the assembly.
  11. Samsung Captivate 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Captivate 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up on the audio jack, taking the attached ribbon cable with it.
    • There is a small amount of glue holding the ribbon cable that attaches the audio jack to the earpiece.
    Be careful when reassembling rear cover as there are 2 tabs at the top of the case that can easily bend and eventually crack of giving no support to the top closure.
    AB Computer Services - crwdns2934203:0crwdne2934203:0
Christopher
crwdns2935283:010/06/11crwdne2935283:0
643 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-25, Maness Fall 2011 crwdns2935289:0Cal Poly, Team 20-25, Maness Fall 2011crwdne2935289:0
CPSU-MANESS-F11S20G25
Between steps 7 and 8, there are a number of steps missing, including the removal of the camera, and the removal of the speaker assembly.
These can be found on the "Mother Board" repair manual, back on the device page.
~Desmond
Mobile Rapid Response Unit - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 7,806
