Samsung Alias 2 Motherboard Replacement
  1. Samsung Alias 2 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press down on the back cover of the phone and remove it.
  2. Samsung Alias 2 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the battery from the device.
  3. Samsung Alias 2 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 4.2 mm screws from the four corners of the battery slot.
  4. Samsung Alias 2 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to peel off the Verizon logo tab from the top of the back cover.
    • The tab is secured with glue, so peel it off gently.
  5. Samsung Alias 2 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 4.3 mm screws that are now exposed using a Phillips screwdriver.
  6. Samsung Alias 2 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to remove the back outside casing.
    • Be careful not to lose the side buttons, as they may come off when removing the casing.
  7. Samsung Alias 2 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull up the yellow tab to prepare for disconnecting components.
  8. Samsung Alias 2 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to disconnect the connecting cord.
  9. Samsung Alias 2 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the rectangular ribbon cable by carefully pulling it out of its connector.
  10. Samsung Alias 2 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift and remove the logic board from the device.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Chris
crwdns2935283:004/16/11crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-35, Maness Spring 2011 crwdns2935289:0Cal Poly, Team 12-35, Maness Spring 2011crwdne2935289:0
CPSU-MANESS-S11S12G35
crwdns2942667:0crwdne2942667:0 2,866
