crwdns2959928:0crwdne2959928:0 ↓If your Samsung Alias 2 phone is malfunctioning or not powering on, it might be due to a faulty motherboard. This guide will walk you through the process of removing the old motherboard and installing a new one.
Replacing the motherboard can restore the functionality of your device. Be sure to carefully follow each step to avoid damaging any internal components. Make sure to power off the device completely and disconnect it from any external power source before beginning.
Press down on the back cover of the phone and remove it.
Take out the battery from the device.
Use a Phillips screwdriver to remove the four 4.2 mm screws from the four corners of the battery slot.
Use a plastic opening tool to peel off the Verizon logo tab from the top of the back cover.
Remove the three 4.3 mm screws that are now exposed using a Phillips screwdriver.
Use the plastic opening tool to remove the back outside casing.
Gently pull up the yellow tab to prepare for disconnecting components.
Use tweezers to disconnect the connecting cord.
Disconnect the rectangular ribbon cable by carefully pulling it out of its connector.
Carefully lift and remove the logic board from the device.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
