Samsung ATIV Book 9 Plus Charger Port Replacement
  1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Charger Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 4.3mm screws holding down the plastic cover using a #000 screwdriver. After the screws are out remove the cover.
    • Remove the 4.3 mm screw holding down the metal cover using a #000 screwdriver.
  4. Samsung ATIV Book 9 Plus Charger Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the charging port from the motherboard by gently tugging on the plastic part of the connection.
  5. Samsung ATIV Book 9 Plus Charger Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge a plastic opening tool or spudger in between the laptop casing and the port. Pry until you feel it release.
    • This will take some force because the port is glued to the casing.
  6. Samsung ATIV Book 9 Plus Charger Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the disconnected charger port.
Casey Kauffman
crwdns2935283:011/06/17crwdne2935283:0
329 crwdns2915208:0crwdne2915208:0
IUPUI, Team S6-G6, Baechle Fall 2017 crwdns2935289:0IUPUI, Team S6-G6, Baechle Fall 2017crwdne2935289:0
IUPUI-BAECHLE-F17S6G6
crwdns2942667:0crwdne2942667:0 2,069
