If your laptop is experiencing display issues such as bad resolution, flickering, or black dots, and/or is physically damaged or broken, replacing the screen may solve these problems.
Be sure the computer is off, and open the computer so that the screen is showing.
Use the plastic opening tool and pry away the casing surrounding the screen. Remove the casing entirely.
Remove the four 3.5mm screws securing the screen.
Place the screen gently on the keyboard.
Remove the ribbon cable from the screen.
Remove and replace the screen.
Where do you buy the replacement screen for the ATIV Book 4? Thanks!
