Saeco Minuto Flowmeter replacement
  1. Saeco Minuto Flowmeter replacement, opening procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the power plug!
    • Remove the water tank.
    • Remove all the coffee beans.
    • Remove the brewing assembly.
    • Remove the drip tray and the coffee grounds drawer.
  2. Saeco Minuto Flowmeter replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up with a plastic opening tool at the bottom edge of the chrome-plated cover to lift up the coffee dispensing spout. This cover is often very tight, so you have to pry hard and hope that the part does not break.
    • When the lower edge of the spout is released, you can pry on the side edge until the chrome cover comes off completely.
  3. Saeco Minuto Flowmeter replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Torx T10 screw at the top edge of the coffee dispensing spout.
  4. Saeco Minuto Flowmeter replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift off the black cover over the coffee dispensing spout. The sliding nozzles will come off at the same time.
  5. Saeco Minuto Flowmeter replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both Torx T10 screws on the left and right at the bottom edge of the coffee dispensing spout.
    • Pull off the hot water dispensing spout.
  6. Saeco Minuto Flowmeter replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Torx T20 screw on the finger guard of the grinder. Remove the finger guard.
    • If the screws are covered with coffee remains, you should first clean them with a needle and a vacuum cleaner.
    • Remove three Torx T10 screws in the bean container.
  7. Saeco Minuto Flowmeter replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three Torx T10 screws under the water tank.
  8. Saeco Minuto Flowmeter replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the upper cover on the sides and lift it up.
    • The cover is still connected with a cable and a tube.
    • Take off the silicone tube.
  9. Saeco Minuto Flowmeter replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the water level sensor cable from its brackets.
    • Carefully remove the plug from the water level sensor.
    • The cover is now free and can be removed.
  10. Saeco Minuto Flowmeter replacement, remove outer casing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saeco Minuto Flowmeter replacement, remove outer casing: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saeco Minuto Flowmeter replacement, remove outer casing: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the service Dior.
    • Remove five Torx T10 screws.
  11. Saeco Minuto Flowmeter replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one T10 Torx screw securing the top of the grinder.
  12. Saeco Minuto Flowmeter replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you haven't already done so: Unscrew the center Torx T10 screw at the bottom of the coffee spout distributor.
    • Unscrew the Torx T10 screw in the middle left front.
    • Lift the service door up and remove it.
  13. Saeco Minuto Flowmeter replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the Torx T10 screw securing the coffee spout distributor inside.
  14. Saeco Minuto Flowmeter replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the coffee spout distributor up and remove it.
    • The coffee spout distributor tends to be dirty. Open it and clean it thorougly.
  15. Saeco Minuto Flowmeter replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You should now be able to lift the inner frame out of the outer one. On some models, it is still attached with other screws.
    • Lift the inner frame up and remove it from the outer case. It may get stuck a bit, help with a plastic lever tool.
  16. Saeco Minuto Flowmeter replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is what the inner frame looks like from three sides. All components are easily accessible, especially the pump, the flowmeter and the heater.
  17. Saeco Minuto Flowmeter replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • And this is what the completely gutted outer case looks like. It can now be cleaned well.
  18. Saeco Minuto Flowmeter replacement, Flowmeter: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saeco Minuto Flowmeter replacement, Flowmeter: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the machine on its side so the flow meter is on top.
    • Disconnect the silicone tubes from the flow meter.
    • The flowmeter is locked into the inner frame. Using pliers press the white plastic catches on the underside together and press the flowmeter out.
    • Disconnect the flowmeter.
    • Remove the flowmeter.
  19. Saeco Minuto Flowmeter replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saeco Minuto Flowmeter replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Blow into into the lower nozzle into the flowmeter. It should be quite easy and you should hear the turbine buzzing.
    • The upper half of the flowmeter is locked in place with a bayonet catch. Turn the upper part a little counterclockwise.
    • Lift off the upper half. Pay attention to the gasket. The turbine can be easily lifted out.
    • Now you can clean and decalcify everything well. Clean in particular the entrance nozzle, for example with a needle. The opening is quite narrow.
  20. Saeco Minuto Flowmeter replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reassemble the flowmeter and check again by blowing into it to make sure that the water flews free and that the turbine is buzzing nicely.
    • If not the flowmeter has to be replaced.
Repeat the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
285,049 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 57
crwdns2936753:030crwdne2936753:0 256
crwdns2942667:0crwdne2942667:0 9,540
