Saeco Magic Capuccino SIN017 Boiler Removal
  1. Saeco Magic Capuccino SIN017 Boiler Removal, Opening procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saeco Magic Capuccino SIN017 Boiler Removal, Opening procedure: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Never forget: Disconnect the power plug before starting repairs!
    • You can find the model designation SIN017 on the bottom of the machine.
    • Pull off the steam valve knob. To do this, you must pull hard.
    • Remove all attachments, i.e. the water tank and the drip tray.
    • Pull off the Cappucinatore.
  2. Saeco Magic Capuccino SIN017 Boiler Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saeco Magic Capuccino SIN017 Boiler Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saeco Magic Capuccino SIN017 Boiler Removal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two Phillips screws on the back.
    • Lay the machine on its side. Unscrew the two Phillips screws at the front of the underside.
    • Lift off the top cover and set it aside.
    • Do not remove the cover completely. It is connected with many cables. You may be able to disconnect the yellow-green cable from the hot plate, then you have more room to move.
  3. Saeco Magic Capuccino SIN017 Boiler Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here is a view into the opened machine. The components are clearly visible:
    • Pump
    • Boiler with thermal switches
    • Steam valve
  4. Saeco Magic Capuccino SIN017 Boiler Removal, Remove boiler: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the machine on its side. Unscrew the four 8mm cap nuts on the portafilter holder.
    • The bracket is loose, but only goes out the top.
  5. Saeco Magic Capuccino SIN017 Boiler Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Saeco Magic Capuccino SIN017 Boiler Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The steam pipe is inserted into the steam valve, but is held in place by a clamp. Pull out the clamp.
    • Pull the steam pipe downwards.
  6. Saeco Magic Capuccino SIN017 Boiler Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Saeco Magic Capuccino SIN017 Boiler Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Saeco Magic Capuccino SIN017 Boiler Removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the machine upright again.
    • Unscrew the four 8mm screws holding the boiler together with a suitable nut. You may need to counter the nut underneath with an 8mm open-end wrench.
    • Detach the upper half of the boiler. Pay attention to the cables and hoses.
    • Now you can also lift out the bottom part of the boiler completely. Make sure that the holder of the portafilter rests on four nuts.
    • Now is also a good time to check and possibly replace the portafilter seals and the brew screen. Coat the seals with food-grade silicone grease.
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
289 185 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 1,391
