SSD replacement on a Dell XPS 13 9380
  1. SSD replacement on a Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SSD replacement on a Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SSD replacement on a Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Torx T5 driver to unscrew the eight screws securing the back panel.
    • Use a spudger to pry up and loosen the back panel.
    • Lift the back panel up slightly from the non-hinged edge.
    • Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
    • When the back panel clips are free, remove the back panel.
  2. SSD replacement on a Dell XPS 13 9380, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SSD replacement on a Dell XPS 13 9380, Remove the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable from the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the four screws (M2 x 2) securing the battery.
    • Remove the screw (M1.6 x 4) securing the battery.
    • Remove the battery from its recess.
  3. SSD replacement on a Dell XPS 13 9380, Remove the SSD: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • We removed or disconnected the battery to avoid any electrical discharge.
    • 1- Remove the screw (M2x3) that attaches the SSD and its protective frame to the motherboard.
    • 2- Slide the protective frame of the SSD disk slot protection frame and remove it from the SSD disk.
    • 3- Lift the SSD at an angle, then slide it and remove it from its housing.
To reassemble your device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934883:0Schwarzercrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Schwarzer
crwdns2935283:008/07/19crwdne2935283:0
5,200 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
i.Fixit FR Team crwdns2935289:0i.Fixit FR Teamcrwdne2935289:0
Community
crwdns2935297:040crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Thank you for making this!
swosse - crwdns2934203:0crwdne2934203:0
Thanks for the write up. There's only have one little problem. The M2x3 screw that holds the SSD in place is just too tightly fastened for me to remove. I'm concerned if I press too hard on the motherboard that I'll break it. Any suggestions for non-destructive ways to remove it?
Thanks,
Mike
Mike Avery - crwdns2934203:0crwdne2934203:0
Beware: Dell's documentation says the 128GB drive heatsink (aka protective frame?) is not compatible with higher capacity SSD's.
George White - crwdns2934203:0crwdne2934203:0
FYI for anyone having difficulty with the removal. The SSD in my XPS was stuck down wtih a tape.
kcirvam - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 98
crwdns2942667:0crwdne2942667:0 9,291
