S7 MaxV Ultra dock: Suction fan replacement
  1. S7 MaxV Ultra dock: Suction fan replacement, Remove the water tanks and dustbin cover.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the water tanks and dustbin cover.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the water tanks and dustbin cover.: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the water tanks and the dustbin cover.
  2. S7 MaxV Ultra dock: Suction fan replacement, Remove the back cover.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the back cover.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the back cover.: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws using a PH2 screwdriver.
    • Pull the back cover off.
  3. S7 MaxV Ultra dock: Suction fan replacement, Disconnect connectors from motherboard.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Disconnect connectors from motherboard.: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect marked connectors from the motherboard.
    • You can disconnect all of them, but it's not necessary.
  4. S7 MaxV Ultra dock: Suction fan replacement, Remove the maintenance brush water output tube.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the maintenance brush water output tube.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the maintenance brush water output tube.: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the zip-tie.
    • Disconnect the maintenance brush water output tube.
  5. S7 MaxV Ultra dock: Suction fan replacement, Disconnect the water intake tube.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Disconnect the water intake tube.: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut off the ziptie.
    • Disconnect the tube from the valve.
  6. S7 MaxV Ultra dock: Suction fan replacement, Disconnect the dirty water tube.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Disconnect the dirty water tube.: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the dirty water tube.
    • It is only necessary to disconnect it from the bottom and not also from the top.
  7. S7 MaxV Ultra dock: Suction fan replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the wires and tube through the holes into the bottom half of the dock.
  8. S7 MaxV Ultra dock: Suction fan replacement, Remove the right side panel.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the right side panel.: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the right side panel.: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the marked screw using a PH2 screwdriver.
    • Push the side panel towards yourself.
    • Remove the screw using a PH2 screwdriver.
  9. S7 MaxV Ultra dock: Suction fan replacement, Remove the left side panel.: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the left side panel.: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw using a PH2 screwdriver, then slide the panel off.
  10. S7 MaxV Ultra dock: Suction fan replacement, Remove the screws.: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the screws.: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the screws.: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the marked screws using a PH2 screwdriver.
  11. S7 MaxV Ultra dock: Suction fan replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the top half firmly.
    • Pull it apart.
    • Set the bottom half somewhere else, as we will be focusing on the top in this guide.
  12. S7 MaxV Ultra dock: Suction fan replacement, Flip it over.: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip it over.
  13. S7 MaxV Ultra dock: Suction fan replacement, Remove the front cover of the dock.: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the front cover of the dock.: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the front cover of the dock.: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the marked screws using a PH1 screwdriver.
    • Pull the front cover off. It is still held in place by a couple latches.
  14. S7 MaxV Ultra dock: Suction fan replacement, Suction fan cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Suction fan cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic cover.
  15. S7 MaxV Ultra dock: Suction fan replacement, Remove the suction fan.: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the suction fan.: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Remove the suction fan.: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber cap.
    • Take the suction fan out.
    • Pull the foam further down the wires to expose all the connectors, then disconnect those.
  16. S7 MaxV Ultra dock: Suction fan replacement, Replace the suction fan.: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Replace the suction fan.: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect the connectors on the new suction fan, then fit the foam over it.
    • Place it back inside.
  17. S7 MaxV Ultra dock: Suction fan replacement, Rubber cap: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Rubber cap: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Rubber cap: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When fitting the rubber cap back on, ensure that the suction fan is properly positioned, so that the plastic cover will fit over it.
    • Once you've done that, reassemble your device.
  18. S7 MaxV Ultra dock: Suction fan replacement, Ensure the cables are in proper grooves.: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Ensure the cables are in proper grooves.: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 S7 MaxV Ultra dock: Suction fan replacement, Ensure the cables are in proper grooves.: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When putting the halves together, make sure the cables are in their correct grooves.
DegenFixer
crwdns2935283:009/18/24crwdne2935283:0
4,661 crwdns2915208:0crwdne2915208:0
Thank you for this comprehensive guidance
Jana Gardill Fedele - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 153
crwdns2942667:0crwdne2942667:0 1,090
