All individual parts can be replaced on the motherboard as well. Please see additional guides if needed.
Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
Pull back the rubber protection in the top right corner to locate the screw.
Repeat with the bottom right corner and bottom left corner.
Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
Open the device by gently lifting the bottom half away from the top half of the device.
Use your fingers to carefully lift the motherboard from the top half of the device.
Pull away the IO shield from the motherboard using your hands.
Buenas tardes exelente guía
06xcat -
Great where to you get the motherboard?
I had face the same problem in my Roku Streaming Device, so I looking for a solution and I found in internet, https://roku.techpal365.com, this website have the solution for your issues even you can also call to their toll free number.
Praba Karan - crwdns2934203:0crwdne2934203:0
