Roconia Q6 Lamp Replacement
  1. Roconia Q6 Lamp Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roconia Q6 Lamp Replacement, Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip your device upside down so that the interface is facing downwards.
  2. Roconia Q6 Lamp Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The device is supported by rubber pieces located at the bottom extremities.
    • There are screws beneath the rubber pieces that can be removed. Remove all four 1.1 mm Phillips #1 screws by using the Phillips #0 screwdriver.
  3. Roconia Q6 Lamp Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn device over again and pry open the device to remove the cover.
  4. Roconia Q6 Lamp Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out the cable that is connected to the top cover to fully separate.
  5. Roconia Q6 Lamp Replacement, Lamp: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement, Lamp: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement, Lamp: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • We need to locate the screws which are holding down another plastic covering.
    • Use a Phillips #1 screwdriver to remove each of the highlighted 8.8 mm screws.
  6. Roconia Q6 Lamp Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There is another screw holding down the plastic covering and it is located on the motherboard. With the same screwdriver, remove that screw.
    • Now carefully pull out the highlighted cables that is connecting to the motherboard that will prevent you from completely removing the plastic cover.
  7. Roconia Q6 Lamp Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • From here you will be able to safely remove the plastic covering and expose a second layer of parts.
  8. Roconia Q6 Lamp Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roconia Q6 Lamp Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • We can now locate the lamp which is being held in place by the mirror part.
    • Carefully remove the mirror, without putting any smudges on the inside from our finger.
    • From there you will be able to remove the lamp and replace.
Elizabeth
crwdns2935283:002/08/24crwdne2935283:0
244 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 4-4, Harold Spring 2024 crwdns2935289:0University of North Texas, Team 4-4, Harold Spring 2024crwdne2935289:0
UNT-HAROLD-S24S4G4
Can you tell us what type of bulb it is? I've been looking for information regarding bulb type and there's no where in the manual or online that has that info. Thanks!
Mischief Makers - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 590
