Roborock Q5 Pro: Laser Distance Sensor Replacement
  1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip it on its head, then remove the dustbin.
  2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bottom cover.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bottom cover.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the side brush using a PH2 screwdriver.
    • Remove the screws using a PH2 screwdriver.
    • Then, pull the bottom cover off.
  3. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift it up on the left.
    • Detach the connector by squeezing the release tab, then pull it out.
    • Do not simply yank the battery out. You will tear the connector off the motherboard.
  4. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper's lid.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper's lid.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the marked screws using a PH1 screwdriver.
    • Then simply lift the lid off.
  5. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper.: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the robot over.
    • Tilt the bumper forwards and move it upwards to remove it.
  6. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the side brush motor.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip it back over.
    • Simply lift it out.
  7. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the chassis screws.: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the marked screws using a PH2 screwdriver.
  8. Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The chassis will still be held together by a couple latches on the back.
    • Use a prying tool to get these apart before taking it apart.
  9. Roborock Q5 Pro: Laser Distance Sensor Replacement, Take it apart!: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Take it apart!: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip it over and simply pull the chassis halves apart.
  10. Roborock Q5 Pro: Laser Distance Sensor Replacement, Screeeeeeews.: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here are the screws organised by steps and type.
    • Use this if needed as a reference during reassembly.
  11. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Then, remove it.
  12. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the LDS towards the right, then disconnect the connector.
    • If you're replacing the LDS, simply insert the new one and reassemble your device.
  13. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber band using some tweezers, forceps or your fingers.
    • Make sure to clean it. This one was quite dirty, which was causing the motor to seize.
    • Your robot may have a different iteration of the LDS, which has a cover over the rubber band section. In that case, please check: Roborock Q Revo: Laser Distance Sensor Replacement and skip to step 12.
  14. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before removing the motor, flip it over and check whether it has a connector or is soldered directly onto the PCBA.
    • Remove the screws.
    • Now you can remove and replace the motor.
    • Your robot may have a different iteration of the LDS, which needs it's driving wheel removed before you can remove the screws. In that case, please check: Roborock Q Revo: Laser Distance Sensor Replacement and skip to step 12.
DegenFixer
crwdns2935283:009/18/24crwdne2935283:0
5,021 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 96
crwdns2936753:030crwdne2936753:0 454
crwdns2942667:0crwdne2942667:0 4,066
