This guide will give detailed steps on how to replace the capacitor in the Ring Video Doorbell Pro.
Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
Use your thumbs to apply downward pressure on the glass part of the device while pulling the faceplate up and off of the device.
Using a PH-000 screwdriver, unscrew and set aside all four of these 5.25 mm screws.
Using a plastic pry tool, go along the edge of the device prying the device apart. While doing this, focus on the four clips, two of which are on either side of the device.
Remove the front of the device from the back plate.
With the Video Doorbell Pro opened up the speaker is exposed.
Remove this wire connection by gently prying it off with a plastic pry tool.
Remove the speaker from the device.
The next step is to remove the last four connections holding the motherboard in place.
Using the plastic pry tool, carefully remove this wire connection.
Using the plastic pry tool, gently ease this ribbon cable from its port.
This step is not needed. The ribbon connects to a daughter board below main board (see pic for step 15) and they will move together. So this is not an obstacle to access a capacitor or battery/antenna combo.
Remove the last two wire connections shown here using the same methods utilized in the previous steps.
Using the Phillips 000 screwdriver, remove these three 4.25mm screws.
I’m not sure you have to remove the black screws, I think they hold the camera lens holder to the motherboard.
Take the motherboard out of the housing. Lift slowly while doing this to make sure the wires and the delicate ribbon cable are not damaged.
Remove the capacitor.
CAUTION:
You need to add to the ribbon cable removal that the ribbon cable pulls out of the white socket. Do not pry up on the white socket as you will break the soldier connections.
To reassemble your device, insert the new capacitor and follow these instructions in reverse order.
crwdns2935229:05crwdne2935229:0
crwdns2947412:08crwdne2947412:0
where can I buy the replacement capacitor please or is it a case of buying a standard and making up the lead?
is that a battery right next to it? why didn’t you pull/mention that also?
I have the ring pro. What is the battery specification and what is the capacitor specification? If I going to all that work I need the replacement parts on hand.
The capacitor is a 470 uF/ 50 VDC electrolytic capacitor.
Battery is 350 mAh 3.7 volt Li 602030.
602030 battery listing: https://www.aliexpress.com/item/33029703...
tmiller -
What symptoms do you have that is causing you to replace the capacitor?
What symptoms do you have that is causing you to replace the battery ?
My inside chimes only chimes when it is cool outside or just randomly. It is hard to track down. The transformer seems strong.
Respond to Kent’s questions please!!!!
Where can I get a new glass plate? Delivery people have broken the glass. Picture and everything works fine.
CAUTION:
