Ring Video Doorbell Camera Replacement
  1. Ring Video Doorbell  Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminum plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell  Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell  Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell  Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Plating Tool Opener, arefully disconnect the ribbon cable that attaches the camera to the housing.
    • Replace camera, and follow the steps in reverse order to reassemble
    Where do you find the replacement camera dropped mine and cameras lens busted?
    Michelle McCord - crwdns2934203:0crwdne2934203:0
    Ok now now that you told me how to replace the camera. Where can I buy a camera to replace my scratched and broken lens?
    Help!??
    Evrt M - crwdns2934203:0crwdne2934203:0
    Same here, where do you get the replacement from?
    Steve.D70 - crwdns2934203:0crwdne2934203:0
  5. Ring Video Doorbell  Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 1 mm screws using the PH00 Philips Screwdriver.
    • Detach the black and red wire connected to the motherboard, using the tweezers, to remove the camera.
Isaiah Wilson
crwdns2935283:002/20/18crwdne2935283:0
231 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S11-G5, Cheng Spring 2018 crwdns2935289:0USF Tampa, Team S11-G5, Cheng Spring 2018crwdne2935289:0
USFT-CHENG-S18S11G5
crwdns2947412:010crwdne2947412:0
What camera should I use to replace a malfunctioning camera in the ring video doorbell? And where do I buy it?
jonathan.byus - crwdns2934203:0crwdne2934203:0
Bump. What camera should I use to replace? (Scratched Lens.) Is the lens you can touch, a lens, or is it just a cover? Mine fell at there is chip right in the center that make the image unusable.
Bobby Diggins - crwdns2934203:0crwdne2934203:0
I have a scratch dead center of mine too. Have no clue how it got there as I’m super careful when I take it off to charge. Ugh. did you find out where to buy a replacement?
Kim Townsend -
What camera should I use to replace? (Scratched Lens.)  I have the right 1st generation with a 740p camera
meanltltoo - crwdns2934203:0crwdne2934203:0
Has anyone found a replacement camera online?
christina.stewart - crwdns2934203:0crwdne2934203:0
So what's up with trying to find a replacement camera cuz my lens is broken?
I also need to know where to buy the replacement lens?? I’m not seeing that question answered by anyone….
Dawn Smith - crwdns2934203:0crwdne2934203:0
Same here, pointless showing how to replace it if we don’t know where to get a replacement other than a used item.
I also need to replace my camera because the very center got scuffed up (no idea how…I’m careful AF with it). Where can I get one?
Bryann Robinson - crwdns2934203:0crwdne2934203:0
All very well but no info on where or what to look for online to buy a replacement.
carl carsboult - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 131
crwdns2942667:0crwdne2942667:0 17,696
