If your hair dryer is not blowing out hot air, has a restricted air flow, or is producing a burnt smell, the air inlet may be defective. The air inlet is a vital source of the hair dryer as it protects the mesh filter from any further debris or damage. As a result, this guide will teach users how to properly replace this component of the Revlon One-Step Hair Dryer.
First, remove the pink panels on each side of the handle in order to access the screws.
After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
Next, completely remove the screws out of the dryer handle.
Remove the barrel by twisting and pulling it away from the handle of the dryer.
I was only able to remove the brush after I used a flathead to pull the main black pieces on the handle away from the brush. These black pieces lock the brush into place.
Thank you, so helpful. I was about to just throw it away.
Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
I can't slide down the air inlet, it is fixed somehow. I can rotate it as much as the setting dial but no more. Any ideas?
it's the same for me.
Can we have a video please ?
I used an adjustable plier to firmly grab the solid portion of the air inlet closer to the power cord, and twisted it counterclockwise until it clicked, then slide out
This does not "slide"
Yes it does slide - I made a short video https://youtu.be/PyEq7-DLC08
dit kankerhoeren ding gaat niet open zie ik eruit als mo bicep ofwat denk het even niet, hasan waarom own jij een vrouwen fohn
There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
Next with your free hand carefully pull the cord out of the port of the dryer handle.
Where do I find that cord? Guide is easy to follow but I can't find it anywhere.
Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
Remove the air inlet by sliding it completely off of the wire.
Take the lint filter out from the air inlet by peeling it from the sides.
Once the lint filter is detached from the plastic filter protector, you can now replace it.
"Slide down the linlet" I've been trying to twist and pull it in every direction possible but it won't come off. How do you just "slide" it down? my type is the RVDR5222
What is a fix it opening tool?
amg3232@yahoo.com - crwdns2934203:0crwdne2934203:0
Donde compro el barrel
Joan2apie - crwdns2934203:0crwdne2934203:0
You don't actually have to take these off. Why not just start on step 4 and 5, then do step 1? That way the top of the panel can be popped out to get the top screw, and the rest of the panel will come off without breaking the flaps
Val Ion - crwdns2934203:0crwdne2934203:0
