Revising Siemens EQ6 flow meters
  1. Revising Siemens EQ6 flow meters, Remove Siemens EQ Series side panel (tank side).: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Never forget: pull out the mains plug!
    • Remove all attachments such as water tank, pulp drawer, brew group.
    • Remove the coffee container lid and take out all the coffee beans.
  2. Revising Siemens EQ6 flow meters: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two Torx T10 screws at the top of the right side panel.
    • Some models do not have these screws. Then the side parts are only held by catches, some of which clamp very strongly. You may have to detach the back part first.
  3. Revising Siemens EQ6 flow meters: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Revising Siemens EQ6 flow meters: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Revising Siemens EQ6 flow meters: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the machine on its side with the water tank side facing up.
    • The side panel is essentially held on the ground by five strong catches. Pry up the pegs with a strong prying tool. It's pretty difficult and you need a lot of strength.
    • If the catches are loose, you can pull the side panel away from below. But it's still stuck in other places.
    • Use a plastic tool to pry the top cover up a few millimeters and lift off the side panel. Most of the time it's still stuck, especially at the front edge, you have to pull hard.
  4. Revising Siemens EQ6 flow meters: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You may need to pry the front edge with a plastic tool.
    • Lift the side panel off, but don't remove it completely yet. It is still connected with a silicone tube.
    • The water tank lid is located at the top of the side panel. Lift it up off the hinges.
  5. Revising Siemens EQ6 flow meters: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the silicone hose that leads to the water connection of the tank from the inside.
  6. Revising Siemens EQ6 flow meters: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Revising Siemens EQ6 flow meters: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cover over the electronics.
    • The second picture shows the most important components:
    • heater
    • Ceramic valve/Brew valve (depending on model)
    • electronics
    • pump
    • mute
    • flow meter
  7. Revising Siemens EQ6 flow meters, Flow meter: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Revising Siemens EQ6 flow meters, Flow meter: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The flow meter is located in the rear left corner. You can remove it or open it while it is still installed.
    • All flow meters in coffee machines are the same. Therefore, use the Jura instructions for servicing.
Follow the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
285,098 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:031crwdne2931471:0
crwdns2935297:01,549crwdne2935297:0
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 212
crwdns2942667:0crwdne2942667:0 2,370
