Retro-Bit Retro Duo Reset Button/Power Switch Replacement
  1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one, or more, of the screws. Simply remove the it before the screws.
    • Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not completely remove the top case. There is a small circuit board--which houses two LEDs-- connected to the main circuit board.
  2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case.
    • This step allows easy button access and prevents accidental damage.
  3. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
    • Make sure you pinch both tabs simultaneously, or the button will not pop out.
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
Truong Vo
crwdns2935283:009/25/17crwdne2935283:0
324 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S4-G4, Eyestone Fall 2017 crwdns2935289:0USF Tampa, Team S4-G4, Eyestone Fall 2017crwdne2935289:0
USFT-EYESTONE-F17S4G4
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 840
