Replacing the ball bearing in Squeaky Ceiling Fan
SengChoy Liew
crwdns2944107:0crwdnd2944107:0SengChoy Liewcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 8, 2024crwdne2944111:0
crwdns2931289:01crwdne2931289:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
This repair guide will solve the squeaks sound of the ceiling fan after few years of operation. Youtube guide available show how-to replace the two wear out ball bearing.
crwdns2944105:0crwdne2944105:0
crwdns2936621:0crwdne2936621:0
  1. Replacing the ball bearing in Squeaky Ceiling Fan, Remove the plastic cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan, Remove the plastic cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First, remove the mounting screws of the plastic cover located along the brim, farthest from the centre.
  2. Replacing the ball bearing in Squeaky Ceiling Fan, Removal of the Iron cage: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan, Removal of the Iron cage: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The iron cage is firmly secured by three screws.
    • Out of the six mounting screws located along the inner circle, three of them will be the mounting screws for the iron cage.
    • Remaining six screws will be the mounting screws for the fan blade.
  3. Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the wiring from the terminal block and the capacitor from the bracket.
    • Unscrew the 13mm mounting bolt to remove the supporting rod.
  4. Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the safety cord.
    • Use plier to loosen the holder.
    • The back plate can be removed once all the electric components are removed.
  5. Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be sure to keep the O-ring safe.
    • Knock off the back plate by positioning it up-side down.
  6. Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use three crawl puller, to remove the bearing.
    • Spray lubricant prior to extraction.
  7. Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a two crawl puller to remove the bearing located 4mm away from the tip.
    • Alternatively, it can be knocked off using a chisel from behind through the hole.
    • A long chisel becomes handy !
  8. Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use three sockets to level the rotor core, while giving the bearing a final push.
  9. Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • A 3" long PVC tube of 6/8 " inner diameter, is used to install the new bearing (6302z for this model of fan).
    • Rubber mallet is used to punch the PVC tube during installation.
  10. Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a rubber mallet to install the other bearing onto the shaft. Rubber mallet or wooden mallet prevents damage to the bearing.
    • The same PVC tubing can be used to give the bearing a final push.
  11. Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the ball bearing in Squeaky Ceiling Fan: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply mechanical grease around the inner wall of the iron cage.
    • Be sure to install the O-ring.
    • Installation of fan requires electrical knowledge. Certified personnel are required to install it back on the ceiling.
crwdns2935229:019crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
SengChoy Liew
crwdns2935283:003/12/12crwdne2935283:0
969 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
my ceiling fan would sometimes not start and making rumbling sounds (bearings) i did not want to replace or tear down so lifted plastic cover on top and liberally sprayed machine oil over exposed bearing & through slots underneath wd 40 this has cured problem perfectly just dry bearings would probably be better to use spray grease if you have --cheaper than new fan or bearings and only a few minutes work
daveorme - crwdns2934203:0crwdne2934203:0
My fan was not working what probelm
Govardhan Yadagiri - crwdns2934203:0crwdne2934203:0
Thanks! I took apart my fan, thank you to your precise instructions. Used lithium grease and right now, enjoying quiet fan in my bedroom
Chris murie - crwdns2934203:0crwdne2934203:0
price of the ceiling fan bearing
tophan das - crwdns2934203:0crwdne2934203:0
muchas gracias porel aporte , muy util y bien explicado
saludos cordiales
cuismi - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 90
crwdns2936753:030crwdne2936753:0 314
crwdns2942667:0crwdne2942667:0 65,735
