Repairing a Panasonic SA-HT810V with the H02/H07 error
  1. Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. Repairing a Panasonic SA-HT810V with the H02/H07 error: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing a Panasonic SA-HT810V with the H02/H07 error: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
  3. Repairing a Panasonic SA-HT810V with the H02/H07 error: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before removing top cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Repairing a Panasonic SA-HT810V with the H02/H07 error: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing a Panasonic SA-HT810V with the H02/H07 error: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one
    • Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
    H 02 an a Panasonic VCR can also mean tape broken and wound around capstan next to rubber roller. Ease tape out, remove tape wound around spindle, repair tape with sticky-tape. To remove tape lever up mechanism to the right of cassette, then lever up plastic holding part on the left half-way up cassette, lift door and push cassette out, minor damage may mean cassette needs help ejecting in the future.
    jppretor7 - crwdns2934203:0crwdne2934203:0
Nathan Cheadle
crwdns2935283:004/15/10crwdne2935283:0
161 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 16-5, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 16-5, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S16G5
Thanks you saved my Christmas and nailed this as my wife loves Christmas music in the background for our family dinner. Thanks again and Merry Christmas
Jerry Wayock - crwdns2934203:0crwdne2934203:0
I have a Panasonic NV-SD235 and I have a tape stuck with the error H02.
Mark Zarraonandia - crwdns2934203:0crwdne2934203:0
Can’t get screws undone on ours… Help!
Matthew - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 28,446
