Has your jacket turned a little bit loopy? A loop of thread that has come loose on your Nano Puff ® jacket can lead to runs, snags, and unraveled stitching. Keep your loose threads from getting out of hand with this easy technique.
For replacement parts or further assistance, contact Patagonia Customer Service.
Examine the damage, ensuring that the loose stitching is, in fact, a loop.
Grab a needle threader.
Turn your jacket to the backside, directly below the loose loop of stitching.
Insert the wire on the needle threader through the lining fabric to the front side of the jacket.
Turn the jacket over to the outside.
Check that the wire diamond on the needle threader is poking up through the jacket as close to the loose loop of thread as possible.
Carefully pull the loose thread through the diamond of wire on the needle threader.
Slide the thread up to the top bend in the wire.
The thread should get caught in the top bend of the wire. If it is not caught, gently squeeze the top bend in the wire to catch the thread.
Pull the needle threader back out of the jacket.
crwdns2935229:015crwdne2935229:0
crwdns2944067:06crwdne2944067:0
Thanks! This looks very helpful. Do you literally push the loop of the diamond wire through the jacket material? Do I need to make a hole with a needle?
It must work, but it seems that it would damage the jacket.
Works like a charm, would also work on sleeping bags etc. just repaired a down jacket and a nano puff shirt. Awesome
Where are you guys getting these wire threaders??? This method has only resulted in breaking two different threaders of mine, the fabric is too thick to get the wire through.
If your needle threader is too weak, An alternative would be to insert a sewing needle through the fabric from front to back, leaving just the eye of the needle exposed. Thread the needle with the loop, as if you were threading the needle with a regular piece of thread, and pull the it through. This will be difficult to thread, because that loop is very short, but it is the only way I can think of if the “needle threader” is not strong enough to push through.
Addendum to last comment…. In the beginning, Insert the needle PARTIALLY through the fabric front to back before you thread it with the loop. That is the only way you will be able to get that short little loop thru the eye of the needle. It must be very close to the site that the needle it is entering the fabric for it to reach that eye! The smaller your fingers, the easier this will be !
